Old 01-11-2022, 10:33 AM
stefanboman stefanboman is offline
Default Major bug?? Delay compensation between bed and objects issue
Got in to mixing music in Atmos and discovered that the delay compensation is ignored between bed and objects when I bounce in real time.
It’s fine in offline bounce.
Have duplicated this issue on several systems using only Avid plugins.
I imported a hihat to a new tracking a blank session.
Duplicated that track.
One of the track goes to the bed, the other assigned as an object.
Inserted 5x Avid Pro multiband dynamics on the bed master to simulate a normal amount of delay when having a mastering chain in the mix buss.
The added delay is well within the limits of delay compensation.
I usually bounce in real time as I often mix on a hybrid setup and like to listen while I print.
Probably a habit since I grew up on analogue consoles.
When I print online the delay compensation is ignored between bed and objects resulting in a very un tight master bounce.
When I bounce the same session offline it’s fine.
Very surprised this hasn’t been more noticed!
Noticed it on Pro tools 2021.12 and went back to older version and it’s the same.
So it’s been like this for about a year.
Has this issue been addressed by Avid or is the a solution?
In my book this is a major bug! Making it impossible to bounce in real time.
Stefan Boman
Atlantis Studios-Stockholm
www.parkstudios.se
stefan[at]atlantisstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 07-27-2022, 12:40 AM
LukeHoward LukeHoward is offline
Default Re: Major bug?? Delay compensation between bed and objects issue
We just ran into this on 2022.5 (avoiding 2022.6 owing to other ADM WAV issues). We can't bounce offline as there is a hardware reverb in the chain.
https://lukehoward.com/
Old 07-28-2022, 08:58 AM
Really weird that this hasn’t been fixed yet.
I guess the only way to get delay compensation with hardware inserts is to record the mix with the renderer.
What ADM issues are there on 22.6? Missed that One
Stefan Boman
www.parkstudios.se
Avid S6
EMI TG12345
Neve 8058
Old 07-28-2022, 05:18 PM
Yes, that’s the workaround I used.
https://duc.avid.com/showthread.php?p=2642825
HTML code is On
Major Delay Compensation issues with Dolby Atmos Production Suite Mixchump Post - Surround - Video 5 03-15-2021 01:43 PM
Automation Delay Compensation Bug w/ objects? reichman Post - Surround - Video 6 01-13-2021 07:57 AM
major PT11 delay compensation weirdness. frozenintime macOS 18 02-18-2015 05:38 AM
Behringer ada8000 major Delay issue alarmstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 04-05-2012 02:30 PM
MAJOR delay compensation problem! Very strange! storm-01 Pro Tools TDM Systems (Mac) 42 05-20-2010 12:26 PM
