certain plugins crashing PT
I've used the Raum Reverb plug-in from NI and the AirEQ and InfinityEQ from Slate for the past year or so with no issues, but all of a sudden, these plugins crash my sessions. I've tried un/reinstalling them and updating them but they just keep crashing, which is annoying because I use them a lot.
I've tried googling but nowhere has what I need, any help would be appreciated also I am on Win10, Ryzen 7 and 32GB RAM, I can't remember specifics but it's a very good PC so shouldn't really be having this issue |
Re: certain plugins crashing PT
Hi, welcome to the community.
Yes, you are right. Even one badly behaving plugin may crash PT even if it is only loaded into memory and not used in a session. That however should be addressed by the plugin makes, it is not PT issue.
when I use these with OBS there is no problem, is there some form of plugin troubleshooting I can do? literally any help other than "not our problem"? |
Well yes and no.
Some plugin vendors do not really code for AAX and AU and VST separately, but instead code once and wrap later. That kind of shortcut may cause troubles fast. So while common denominiator may seem to be PT, the fact still is even ONE bad plugin may cause trouble in PT and even if not used in a session -- it is perfectly enough that the plugin is loaded into memory. Troubleshooting would be throwing all plugins to unused folder, then move them back one vendor at a time. Once you hit trouble, you know which one it is. Move it back to unused, continue moving others in and confirm the problems stay away. Then start moving that vendor's plugins in once by one. Same thing, once you hit trouble, you know that plugin caused it. Once you have pinpointed the problematic plugin, contact that vendor and ask for help. Needless to say plugin versions must match PT version.
2 plugins crashing Pro Tools | freakhouse | macOS | 2 | 09-19-2021 10:51 AM |
PT 5.31 TDM Plugins Crashing Bug **** | David Correia | Pro Tools TDM Systems (Mac) | 1 | 04-16-2012 07:43 PM |
Plugins Crashing | gwsoundguy | VENUE Live Sound Systems | 1 | 08-04-2009 12:24 PM |
Trouble with plugins crashing program. (PC) | emersonrailroad | Pro Tools M-Powered (Win) | 17 | 11-18-2008 12:12 PM |
Crashing using AudioSuite plugins? | cc1 | Pro Tools TDM Systems (Mac) | 4 | 08-22-2004 09:47 AM |
