Old 03-15-2021, 12:02 PM
liquidshock liquidshock is offline
Default A script for "Show/hide automation lanes" ?
Hi guys,
does anybody know a script for the shortcut of the button "Show/hide automation lanes" , please ?
Thank you very much !
Old 08-16-2021, 06:57 AM
Oliver M Oliver M is offline
Default Re: A script for "Show/hide automation lanes" ?
Originally Posted by liquidshock View Post
Hi guys,
Here's an AppleScript to Show/hide automation lanes for the currently selected track.
Code:
if ptIsRunning() then
    tell application "System Events"
        tell process "Pro Tools"
            set frontmost to true
            tell (1st window whose title contains "Edit: ")
                try
                    set selectedTrack to title of button of UI element 2 of (1st row of table "Track List" whose selected is true)
                    set targetTrack to text of selectedTrack as string
                    set AppleScript's text item delimiters to "Selected. "
                    set fullTrackName to every text item of targetTrack
                    set AppleScript's text item delimiters to ""
                    set targetTrack to fullTrackName as string
                on error e number n
                    if the n is -1719 then
                        tell application "Pro Tools" to display alert "No track was selected." message " " buttons {"Cancel"} default button 1
                        return
                    else
                        tell application "Pro Tools" to display alert "An Error Occurred" message e & " (" & n & ")" buttons {"Cancel"} default button 1
                    end if
                end try
                click UI element "Show/hide automation lanes" of group targetTrack
            end tell
        end tell
    end tell
end if
on ptIsRunning()
    return application "Pro Tools" is running
end ptIsRunning
Old 11-26-2021, 02:00 PM
I read only now !!! you're a genius ! Thank you very very very much !!!!
Old 01-17-2022, 04:23 PM
You are welcome but no, I am no genius by far. But you may consider to watch the Tips & Tricks section more closely or consider to pay for your custom wishes. Not everything in life is for free. Just a hint.
Hide automation lanes? [solved] dg27 Pro Tools 11 6 03-14-2023 11:39 AM
Shortcut for "show all used automation" jorg Pro Tools 9 15 08-26-2016 04:19 PM
Is there a way to unlink "Track Show/Hide" between mix and edit window? Tobias Eichelberg Pro Tools TDM Systems (Mac) 13 09-25-2010 01:23 AM
Weird Bug??! 8.0.3 will not "remember" which playlist lanes are hidden! cabbagerock Pro Tools TDM Systems (Mac) 5 05-10-2010 12:21 PM
Show Hide Automation Lanes - Shortcut ? Tomy DeClerque Pro Tools TDM Systems (Win) 0 02-07-2009 04:06 AM
