Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 06-29-2020, 11:07 PM
NateAlexander NateAlexander is offline
Default How Is Sample Rounding STILL A THING
I cannot believe this is still an issue in Pro Tools.
For anyone who doesn't know what I'm talking about, it's a long-standing issue where Pro Tools (doesn't happen in ANY OTHER DAW) fails to properly accommodate pasting of audio to the grid of certain sample lengths against certain tempos. Essentially what happens is you will duplicate a clip a few times and eventually it will just be off grid-- and no it has nothing to do with no selecting a whole grid's worth of a region or anything basic like that.
So the question is how has this not been addressed? What happens at Avid Connect every year that nobody complains about this HUGE insane issue?
Old 06-30-2020, 01:43 PM
innesireinar innesireinar is offline
Default Re: How Is Sample Rounding STILL A THING
Speaking of audio every daw snap material to the closest sample and most of time that sample could not match to a given bar/beat. I think that other daws make a graphic adjustment in order to see the clips quantized to the musical bar/beat resolution. Just my tought. What is unaceptable is the fact that this happens on midi clips as well. And this is driving me (and others here on the duc) crazy. Clips that change name when moved/copied, clips with notes that when changing tempo are no longer quantized on the bar/beat grid. Furthermore this didn't happen before PT12. Don't know what the hell they did on the midi "engine" with the 12 release. I am unable to program midi properly on PT newer than the 11 version.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
Old 06-30-2020, 01:49 PM
JFreak's Avatar
JFreak JFreak is online now
MIDI is never sample accurate. Data rate being 31250 bits per second it does not match any audio sampling rate at any DAW.
Janne
Old 06-30-2020, 02:15 PM
arche3's Avatar
arche3 arche3 is offline
I dont even notice it anymore... lol.
Sent from my SM-G986U using Tapatalk
Old 06-30-2020, 03:12 PM
Yes, you are right. But all other daws that treat midi properly have midi resolution matched to the bar/beat grid and not related to audio samples. Anyway PT 11 didn't have this issue.
Old 06-30-2020, 03:21 PM
foxes's Avatar
foxes foxes is offline
Exactly and PT is the ONLY DAW that cannot, will not or do not know how to fix it.......for crying out loud!!!!!
What a JOKE!!!!!
http://duc.avid.com/showthread.php?t=409558
http://duc.avid.com/showthread.php?t=404739
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
Old 06-30-2020, 04:28 PM
What a JOKE!!!!!
They should simply restore the old midi engine that worked fine.
Old 07-01-2020, 02:11 PM
XJENSEN XJENSEN is offline
Probably not that simple to do..
Old 07-02-2020, 02:43 AM
take77 take77 is offline
I've discovered I can't use the cut/insert time function either because of this.
At least not with a project of varying tempos.
It results in the misalignment of every single clip (both audio & MIDI), every MIDI note pattern & marker placement.
Last night, I went to cut the intro section of my project to shorten the length of the track and start the shorter version from Bar 1.
Should have been quick & easy.
Before doing so, I made a backup file because I knew what might happen.
Sure enough, I had to re-align EVERY single audio & midi clip along with every single marker.
Everything was shifted just under a 64th note off the start of each measure.
Got halfway through sliding everything back onto the grid and finally gave up.
Reopened the saved session and will just have to start the song 16 bars in.
Anyhow, I'm not sure if this would happen if the song was all one tempo.
At least I know to use PT 11 on my laptop to do any kind of cuts or insertions.
As well as any other MIDI pattern creation or arranging.
Old 07-02-2020, 03:27 AM
Unbelievable..
Sample Rounding Issue!!!! foxes Pro Tools 2019 185 07-03-2022 03:59 AM
Sample Rounding budda963 Pro Tools 11 1 07-08-2013 06:07 AM
Sample rounding issues bigdoghat 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 11-13-2007 08:20 AM
Sample rounding, ticks, etc voce Pro Tools TDM Systems (Mac) 1 08-03-2005 05:26 AM
ENUFF GRABASS!!! Sample-rounding BUG!! s2n Pro Tools TDM Systems (Mac) 9 02-15-2004 01:51 PM
