Old 06-20-2020, 02:37 PM
Dizzi45Z Dizzi45Z is offline
Default "Select Assignments to" - Changed to show hidden tracks [PT-263050]
So recently "Select Assignments to" has changed in a horrible way for me.
It used to be that whenever you wanted to select tracks with the same assignment, you could right click on an output or send and choose, "Select Assignments to..." and all of your tracks currently showing that had that assignment would select. This was perfect and didn't mess up your session with tracks you had hidden.
Now, when you do the same thing, it will unhide all of the tracks with the same assignment. This is so frustrating because I don't care about HIDDEN tracks with those assignments as they are often hidden because I am currently not using them or they are just there for archiving parts of the session.
Is this a new bug that has been introduced? or was there a decision made to change this behavior. If so, I really wish there was an option to have it ignore hidden tracks like it used to do.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 06-20-2020, 11:38 PM
cwsand's Avatar
cwsand cwsand is offline
Default Re: "Select Assignments to" - Changed to show hidden tracks.
I never used this feature before, but it works on mine the way you described. The Reference Manual says "Show Assignments To - This option shows all tracks, including hidden tracks, that use a specific input, internal bus, output bus, or hardware insert. All other tracks remain shown as well." Wish there was a way to ignore hidden tracks.
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 06-22-2020, 11:11 PM
This change happened just recently with folder tracks. Everything works as expected on 2019.12, but ever since then, I think it has been different.
I believe the change happened because since folder tracks do not show the closed folder tracks in the tracks list, when you interrogate to select tracks that have certain parameters, it opens folders and unhides any tracks with those parameters. I don't mind that it opens the folders so you can see what is selected in the tracks list, but I HATE that it unhides all tracks that I have hidden that have those parameters. Especially ones that I have hidden and made inactive.
160 GB RAM
macOS 11.7.4
Old 07-03-2020, 03:45 PM
Astrojerry Astrojerry is offline
Im glad I'm not the only one experiencing this. It used to be the way I could quickly assign headphone sends to the tracks that need it but now it just unhides all of the previously hidden tracks making it a nightmare!
Have you found any way around it Dizzi45Z?
Old 07-03-2020, 03:59 PM
bartosz idzi bartosz idzi is offline
Why not file a support claim at Avid's support portal?
Mac Pro 2 x X5690 3.46Ghz - 64 Gb RAM - SSD 256 Gb - SSD 1TB - OS 10.14.6 - Metric Halo 2882 + Lucid 88192 - Pro Tools Ultimate 2020.11
Old 11-04-2020, 04:11 AM
gonzolagonda gonzolagonda is offline
Any solution to this yet?
PT2023.12 - Mac Studio M1 Max 64GB RAM - macOS 13.6.3 - UAD-2 Satellite Octo/Apollo 8tb Duo/Apollo 16ii/Prism Lyra 2 - Euphonix Artist Control - All the plugins(!) Waves/PA/Slate/SSL/McDSP/UAD/Kush/SoundToys/Eventide/Softube/NI/PSP/Sonible/BABY/Fabfilter/Sonnox etc.
Old 11-04-2020, 05:50 AM
This absolutely kills my workflow. I would rather not have folder tracks than have this broken. There are so many times in large sessions that I need to see routing to certain busses, etc and having this mess up my show and hide tracks in the session is absolutely frustrating and makes the feature absolutely worthless. The closest workaround I have is that I save a memory location with the show and hide tracks and then after making the inquiry, recall the memory. This still is a pain because if I am trying to change the routing, I have inactive tracks that are being affected.
160 GB RAM
macOS 11.7.4
Old 02-21-2021, 10:07 AM
EdgarRothermich's Avatar
EdgarRothermich EdgarRothermich is offline
Correct. It worked fine in 2019.12
This is truly a terrible change, intentionally or just an oversight.
One solution is to have two select commands, with or without the Hidden Tracks. And also the other Restore command that is available in the Track List Menu
  • Select Assignments to ... (only Shown Tracks)
  • Select Assignments to ... (including Hidden Tracks)
  • Restore Previously Shown Tracks
Edgar Rothermich
Author of "Pro Tools 2020 - How it Works"
from the Graphically Enhanced Manuals (GEM) series
http://DingDingMusic.com/
YouTube Channel Music Tech Explained https://YouTube.com/c/MusicTechExplained/
Old 02-21-2021, 11:23 AM
Great idea!!! Unfortunately it doesn’t seem like enough people care for this issue to be addressed.
160 GB RAM
macOS 11.7.4
Old 02-21-2021, 12:40 PM
reflexson reflexson is offline
Yeah this is unfortunate. When I can remember, I change the output path of a track I’m going to hide and make inactive to an unused bus. Really stinks.
Paul Cox
www.226recordings.com
"Select Assignments to" is not working correctly! It shows the hidden tracks! Electronic1982 Pro Tools 2 06-20-2022 12:42 PM
Show tracks inside folders with folder hidden snowplaysmusic Pro Tools 3 06-22-2021 03:58 PM
After update hidden and inactive tracks show on s1\dock\control app ramonetl Avid S1, S3, Dock and Control App 7 06-26-2020 10:29 AM
select only assignments to brdst Avid S4/S6 1 11-05-2016 10:33 AM
No track assignments to hidden tracks! zoundsabar Artist Series 0 01-10-2011 05:12 PM
