Old 03-24-2020, 10:46 AM
Cayce Cayce is offline
Default How to Convince PT there's No Video in the Session
Working on a video soundtrack, I had the video clip on a track in my session but had to pull it out because the PT Video Engine is such a resource hog (4.19gb... really?!) and I kept getting CPU resource overloads. I deleted the video track, removed the video file from my clips manager, got rid of every trace of anything 'video', but PT still says "Restoring Video Files" while opening, hangs at a warning about QuickTime not being able to play the video, and launches the Video Engine, even though 'Video Engine' is not enabled in my Playback settings. Every time I launch this session I have to dispatch the QuickTime warning, then go into my Activities Monitor and force-quit the video engine.
Is there some way of convincing PT there's no video in this session, once and for all?
Thanks.
Pro Tools Studio, 2023.3.0
Mac OS: Ventura 13.4
System: Mac Studio 2023, Apple M2 Ultra, 128GB Unified Memory
2TB Internal SSD
Apple Studio Monitor, 27"
3 External Monitors: 27", 27" & 65"
Apollo X8P Mixer Interface
PreSonus 32R Mixer Interface
Old 03-24-2020, 12:22 PM
Default Re: How to Convince PT there's No Video in the Session
Maybe make a copy of the session and open the copy, then delete the video track?
Old 03-24-2020, 01:46 PM
dougdi dougdi is offline
Make a new session and import all tracks except the video track. Always saved me in that situation.
Old 03-24-2020, 04:18 PM
Southsidemusic's Avatar
Or turn off video engine.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 04-06-2020, 03:16 PM
Had to be away awhile, adjusting to Corona-Crap...
Thanks for the replies, but...
albee1952: as mentioned in the post, there's no video track to delete. That was done already.
dougdi: as mentioned in the post, there's no video track to not import into a new session. It's been deleted already. Besides, with a session of this complexity, your suggestion would be a nightmare.
Southsidemusic: as mentioned in the post, I've already turned off the video engine in the Playback settings, but it keeps activating anyway.
I'll just assume this is yet another PT anomaly with no workaround or solution.
2TB Internal SSD
Old 08-06-2022, 06:57 AM
KevinQ KevinQ is offline
Wondering if you ever got this sorted? I've tried all of the above, the only thing that worked was re-importing session data one track at a time (yes, even though there was no video file not to import). If I import all the tracks at once, whatever ghost or remnant of the video track there is seems to come along with it, but if I import them one or few at a time, saving in between, it seems to work.
As it stands right now, it seems that if a session ever had a video track, opening it will *always* launch the video engine forever after.
Old 08-06-2022, 09:44 AM
Okay, since PT keeps thinking there is a video track, there must be some remnant hiding somewhere. Here are some things to try:
1-Open the session folder and look for a video file. If you find one(or more) move the file(s) out and stash it somewhere else(but NOT on the desktop).
2-Open the session, assuming no video track is visible, select all the tracks and then Export them as a new session(include audio files) and save. Open this new session and see if the video engine stays off.
3-Create a blank session with video engine off. Import Session Data from the original and pay close attention as you select tracks to import(in case there is a hidden video track on the Tracks list).
Fingers crossed that one of these helps
Convince me to get an 11R instead of an Axe Fx II - ver. 11 HwyStar Eleven Rack 9 08-21-2013 01:10 PM
Sharing a video in same session for ADR (video in booth and video in control room) Boogie457 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-01-2010 04:52 PM
Convince me PT was not a mistake. [email protected] 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 77 04-19-2010 05:15 AM
So convince me to record at 48 instead of 96... daede 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 75 11-08-2003 02:27 PM
Convince me I need 6.1! Steve Moore 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 07-04-2003 12:38 AM
