Old 08-07-2018, 02:17 AM
Suddenly Clear Suddenly Clear is offline
Default Menu Names Cut Through
On Windows 10 PC, The menu names are cut through. When PT is loading it's okay, then when finished, it jumps out of full-screen mode and the problem occurs. It persists when you maximise. Here's a screen grab of the issue:
Thanks
Old 08-07-2018, 10:50 AM
cwsand's Avatar
cwsand cwsand is offline
Default Re: Menu Names Cut Through
Hi, start here: Help Us Help You
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 08-09-2018, 01:01 PM
Benoni's Avatar
Benoni Benoni is offline
Mu guess is you have scaling on. Do you have it set to something higher than 100%?
Start > Settings (gear icon) > System > Display.
Scale and layout
Set to 100%
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 08-11-2018, 11:23 AM
Scale and layout
Set to 100%
You guessed right! Thanks, Benoni.
If anybody else has this issue, remember to reboot. I opened Pro Tools with 100% set and still had the same issue. After I rebooted it worked.
Old 09-27-2022, 05:57 PM
pianomanharry pianomanharry is offline
For anyone still having this issue...
I am running Windows 10.
1. I have Pro Tools shortcut on my desktop so I right click on the shortcut and go down and click "PROPERTIES".
2. Click the "COMPATABILITY" tab.
3. Click down the bottom where it says "Change High DPI Settings".
4. At the bottom where it says "High DPI scaling override", make sure that "Override high DPI scaling behavior" is checked and make sure the drop down box says "Application". Click OK.
That did it for me. :)
I / O menu does not exist in the setup menu, Pro Tools First Berry Oaks Pro Tools 12 0 01-19-2017 01:11 AM
Fix manufacturer names with two different spellings in plug-in menu jsbach AAX Plug-ins 2 12-02-2015 05:04 PM
pro tools plugin menu, and options menu blank lucidlife Pro Tools 10 4 12-07-2014 12:16 AM
Menu BUG...Menu FREEZES...Menu LOCKS UP...Restart Pro Tools! a2zproductions Pro Tools TDM Systems (Mac) 16 05-08-2008 08:30 AM
Keyboard shortcuts - duplicate menu item names jeremyroberts Pro Tools TDM Systems (Mac) 0 11-18-2005 02:04 PM
