Old 02-19-2018, 03:08 PM
chalz2502 chalz2502 is offline
Default compress vocals on mic pre or not?
general suggestion, should i compress vocals on the way into protools on my mic pre, or should i bypass the compressor and record with just the mic pre? if so is it safe to use the output as some make up gain? its harder to get a great input signal when you compress on the way in. my wave formats come out very small after recording. i end up having to do allot of make up gain. the more i turn the input gain up, i still dont get a great mic signal depending on the vocalist. the signal would barely hit the yellow. what i realize though is if i use the output as more make up gain, i get a healthier signal. im not sure if thats good or not to use the output as make up gain. what i also realized is if i bypass the compressor, i get the kind of signal im suppose to get. the only problem with that is it dont sound as warm as it does when i activate the compressor. i have 4 tubes inside my avalon, you think they dont activate if i bypass everything? im open to any suggestions. im running protools 10, using a avalon 737 mic pre, neumann 103 mic, and a mbox pro 3 as my interface. i have 4 tubes inside my avalon
Old 02-19-2018, 03:13 PM
Raoul23 Raoul23 is offline
Default Re: compress vocals on mic pre or not?
I always compress a little bit on the way in, between 2-4 dB but if it sounds good do whatever you want there are no wrong or right ways
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 02-19-2018, 03:17 PM
yeah i know this, but what if i get someone who cant record loud enough to get a healthy signal gain. even when i turn the gain input up higher it still a little low. if i used the output to add extra make up gain, is that wise to do?
Old 02-19-2018, 03:47 PM
zedhed's Avatar
zedhed zedhed is offline
My personal preference is to record vocals raw on the way in. The only thing I might do is use a soft clip limiter. Compression can be added later but cannot be taken out when used during recording, so flexibility is key for me. The trick here is to use the right equipment in the first place.
Ideally, getting a strong signal to record is preferable. Adding gain on the output will also accentuate any noise that was recorded on the way in.
What Mic are you using....and does it (or your Mic Pre) have a pad that may be engaged accidentally?
You may want to try a different Mic ( and or singer ).
Too much blood in my drugstream
Motherboard: Gigabyte Z690 AERO D
CPU: Intel Alder Lake Core i9-12900K
CPU Cooler: Noctua NH-D15S
RAM: Corsair Vengeance DDR5 64GB (2x 32gb 5200MHz)
Drives: 2 x Samsung 980 Pro 2TB NVME PCIE 4.0 M.2 SSD (Record & Samples)
1 x Samsung 980 Pro 1TB NVME PCIE 4.0 M.2 SSD (OS Win 11 Pro)
GPU:Gigabyte GeForce RTX 3060 12GB GDDR6 PCIE 4
PSU: Corsair HX Series HX850 Platinim
CASE: Fractal Define XL R2
PT 11HD (v11.3.2) Omni s/pdif <> AxeFxIII
HD 96I/O
Old 02-19-2018, 03:52 PM
i use a neumann 103, and my interface has a -10 db pad, if i go plus 4 i get allota feed back that sounds like air in the background.
Old 02-19-2018, 04:44 PM
zedhed's Avatar
What does it sound like plugging straight into Mbox without the Avalon?
I have to ask the obvious question, is the Avalon input knob turned to Mic position (phantom power on as well)?
How are the Mbox and Avalon connected.....digital?
HD 96I/O
Old 02-19-2018, 04:52 PM
its a good signal going into the mbox, as well as when i bypass the compressor. my mic pre is set to 48v phantom power as well
Old 02-19-2018, 05:00 PM
zedhed's Avatar
Try turning the Avalon Pre Amp gain all the way down (fully anticlockwise), disengage the pad, then slowly turn pre amp gain up incrementally testing signal as you go. At this stage, bypass the compressor altogether.
BTW, what compressor are you using?
How is all this gear connected together?
HD 96I/O
Old 02-19-2018, 07:30 PM
This is THE important question. If the Avalon is patched into the Mbox XLR input, you are slamming a line-level signal into a mic-level input(not a good idea). Use the TRS input and lower the GAIN knob all the way
Poll: Compress or not to Compress EvilElfBoy Pro Tools TDM Systems (Mac) 16 07-08-2009 12:14 PM
How can I compress vocals pre-tape with outboard comp while using 003 pre amp? strangej 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 06-22-2009 10:48 AM
Compress on the way in? MT2008 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-05-2008 08:44 AM
Compress before or after EQ? Hardnox Pro Tools TDM Systems (Mac) 7 08-15-2001 12:36 AM
How to NOT compress vocals? Kickin.da.speaker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-18-2001 06:20 PM
