Old 05-09-2016, 05:46 AM
bing181 bing181 is offline
Default Commit always consolidating clips?
Trying to get my head around Commit.
Have some tracks with separate clips, but when I Commit, the resulting .cm track is always consolidated - even with "Consolidate Clips" disabled (not selected). Same whether I Commit an Edit Selection or whole track.
Thanks in advance.
Old 05-09-2016, 05:57 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: Commit always consolidating clips?
Since 12.5 not in 12.4?
Mac / PC
Old 05-09-2016, 05:59 AM
Ah … I'll answer my own question. I'd delete the post, but can't see how to do it … mods?
Anyway, it's because of the -144 dBFS noise floor. It seems that there are any number of plugins that have low level noise going on in the background, and I seem to use at least one of them on every track (e.g., Saturation plugin, Slate VMR or VTM etc.). These are enough to trigger the audio detection algorithm in Commit.
Any chance of a user-selected threshold, or a work around? Useless for me as it is.
Old 05-09-2016, 06:54 AM
Drew Mazurek's Avatar
simply click edit post.
As for Commit, simply use "selection" rather than selected tracks.
www.drewmazurek.com
Old 05-09-2016, 07:11 AM
If you mean "Edit Selection" as opposed to "Selected Tracks", it makes no difference to the result described above. I'm always getting consolidated clips - because of the plugins and the -144 threshold it seems.
Unless of course I do it clip by clip ... which isn't an option.
Old 05-09-2016, 07:19 AM
got it. yes, dither, analog modeling, verb tails all have content down there.
www.drewmazurek.com
Old 05-09-2016, 08:11 AM
Which makes Commit useless in many cases - or almost all of mine.
Old 05-09-2016, 08:16 AM
IMO, the concept of Commit is to render out and "future proof" tracks you're "done" with. It's perfect for that.
www.drewmazurek.com
Old 05-09-2016, 09:04 AM
Stig Eliassen's Avatar
I'm sure you are aware of this, but as long as you're using plugins that introduce noise/saturation/etc, that is what you're hearing coming through your mix buss, and will therefore be commited. Separated clips in the timeline won't affect that.
Old 05-09-2016, 09:27 AM
Originally Posted by Stig Eliassen View Post
...but as long as you're using plugins that introduce noise/saturation/etc, that is what you're hearing coming through your mix buss, and will therefore be commited. Separated clips in the timeline won't affect that.
Of course. But this is an hour-long session with a dozen or so Cues for a film with bits and pieces all over the place. It has to go to someone else for further editing, and having 40 or or so hour-long clips on each track would be catastrophic in terms of continuing to work with the material. It's essential that all the individual clips remain as they are, noise/saturation/etc. notwithstanding.
Commit adds extra space to the audio clips DJ Hellfire Pro Tools 12 1 04-15-2016 03:58 AM
commit consolidate clips jamesregan Pro Tools 12 0 01-13-2016 07:11 AM
Pro Tools freezes when creating Fades, analyzing EA, or consolidating clips [SOLVED] Beaubien7 Pro Tools 11 15 03-30-2015 12:54 AM
Consolidating Clips/tracks Tampaguitar Pro Tools 11 9 12-20-2013 11:33 AM
consolidating clips correctly..pls..help... chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 05-14-2005 12:22 PM
