Any workaround way of automating the pitch knob in audio suite time shift?
You cant automate audio suite parameters for obvious reasons but I like the effect it makes on vocals when I'm auditioning in Timeshift and turning the pitch knob in real time. How would I record this since you cant actually automate it in audio suite? Maybe use time Pitch II plugin and automate the cents knob? Im assuming automating semi tones would be too big of an interval to compare it to turning the pitch knob in audio suite. I would just try but I'm not at home right now and I just had it on my mind.
Re: Any workaround way of automating the pitch knob in audio suite time shift?
set the output of the track to a Bus (lest say Bus R)
make a new audio track, make it's input Bus R record arm the new track select the clip on the old track bring up the AS plug go into Play/Record adjust the AS plug stop recording
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
Record an AudioSuite Plugin, that outputs to an Audition Path ???
Playback/recording in real time and adjust an AS plugin, where the "Preview Processing" button has not been pressed ? Either playback/recording of the timeline OR pressing the "Preview" button of the AS plugin works. I do not find a way to set an Audition Path to a bus, other than to an output. I can only think of recording the Audition Path (the physical output of the interface) while adjusting parameters of an AS plugin into another recording device.
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
cool thanks ill give this a shot.
Audio Suite Pitch Shift | himynameisdustin | macOS | 11 | 11-09-2015 05:01 AM |
Digi Time Shift Audio Suite bug | saspro | Pro Tools TDM Systems (Mac) | 0 | 01-25-2010 06:22 PM |
Pitch Shift Audio Suite problems | wasabi | Pro Tools TDM Systems (Mac) | 5 | 04-24-2007 08:07 AM |
Audio suite pitch shift makes digital garble | Arts Academy Hel | Pro Tools TDM Systems (Mac) | 4 | 05-15-2005 09:54 AM |
Audio Suite Pitch Shift plug in | sir d | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 05-08-2005 09:40 PM |
