Old 02-19-2014, 02:46 PM
Michael North's Avatar
Michael North Michael North is offline
Default Eleven Rack Editor - Error Initializing MIDI Engine
Bummer ...
Just downloaded the Editor ... and when I try and run it I get ...
"Error Initializing Eleven Rack MIDI Engine"
I've only had it about a week and both audio and midi have been working great with both ProTools 11 and Logic X ... so this is a surprise.
Driver 1.2.0
Firmware 2.00.1
And the Rack shows up fine in Audio MIDI Setup.
Any Ideas?
I'm on a Mac with 10.9.1
Old 02-19-2014, 03:40 PM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Editor - Error Initializing MIDI Engine
Have you tried using a different USB port?
Can you open the Editor with Pro Tools closed?
Have you tried a re-install of the Editor?
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 02-20-2014, 09:25 AM
Thanks for trying to help.
1) Yes, I did re-installed the editor.
I even re-download it ... No Joy
also re-download and re-installed the drivers.
Does the Editor create any files in the system library that I should trash?
2) No, the editor will not open, and it gives the same error
with ProTools open OR closed ...
3) I did try a different port (after you suggested it) ... No Joy
4) I also shutoff the other two interfaces I'm using,
a MOTU 828 and a Apogee Duet ... still No Joy
5) Zapped the Pram
?? Any other suggestions would be greatly appreciated ...
Is there a contact email or URL for the Editor developers/support ?
Line 4 of the installation instructions states:
"iLok License Manager is required and should be installed automatically"
Of corse it's there since I'm running ProTools ... But ... there's no sign of
a license for the Editor.
There's no license required ... right?
Old 02-20-2014, 10:00 AM
junkgear's Avatar
junkgear junkgear is offline
No, you do not need a license to run the editor.
There are two MIDI ports on the 11R; an external and an internal.
I forget how they are labeled in the driver, but make sure that both are enabled in OSX. My guess is that the internal (USB) port is disabled.
Will
System Details
Old 02-20-2014, 10:19 AM
stormstudios stormstudios is offline
Do you have everything permanently wired up? I've noticed that I must have the 11R plugged in and then start up my computer. I can't plug it in with the computer running or I get all sorts of issues or it doesn't even work at all.
Also, the License isn't required but for some reason the License Manager needs to be installed. Weird, right? And the help hasn't been clear enough. The License Manager (or the shared files required for the Editor) was supposed to be installed with the Editor but many had issues where it wasn't actually installing.
Weird that it's working everywhere but that so I'm not sure what other help I can give. I just thought I'd share some of the bg info from other threads.
Old 02-20-2014, 11:29 AM
Ya ... it seems odd to have a problem with Editor when
the Rack is talking to both Logic and ProTools just fine ...
It's hard to see on the Screen Shot I uploaded;
but the MIDI Studio app shows both ports Rig & External "good to go".
Is there someone " directly " responsible for Editor Support
that I can contact?
Thanks guys ... for jumping in ...
File Type: jpg Screen Shot 2014-02-20 at 12.12.31 PM.jpg (67.9 KB, 0 views)
Old 02-22-2014, 05:50 PM
Huh? There are two 5 pin DIN MIDI ports on the 11R (input and output). Those have nothing to do with the USB port which is for control and passing audio to and from the computer. I have never heard of an internal and external MIDI ports. I never had to do anything in OSX AMS to setup the 11R MIDI (I have a separate MIDI interface). The only thing I use the MIDI in port on the 11R is for my Tech 21 MIDI Mouse for patch selection. Didn't have to do anything in OSX AMS or on the 11R for that.
Just forgot something - if there are other MIDI drivers on the computer that will mess up communications with the 11R. I use a lot of Native Instruments vi's and fx in during installation of the Komplete 8 and 9 bundles NI's own MIDI driver for some piece of hardware I don't have was automatically installed. This would interfere with PT10 seeing the 11R and I had to delete the NI driver for things to reliably work.
Jack
QAPLA!
Old 02-25-2014, 10:26 AM
Thanks for jumping in ...
I assumed that the USB was being seen as a MIDI I/O as well; it does transmit MIDI to and from the computer ...
I Am using the Rack as the only MIDI I/O for the Mac. It's been working fine in that role with both PT & Logic.
I Do have Komplete 8 running ... I don't make much use of it ... so if I have to un-install it for a test ... it's do-able ... I can live without it for a while.
I have a support ticket going on this issue now, but the "back & forth" has been a little slow. And it started with the immortal words "We've never seen that before" ) Not exactly encouraging ...
I've also done all three levels of re-initializing that I know of.
And I eliminated the MOTO and Apogee interfaces for now; and removed them
from the Aggregate I/O. (Support tells me it's to be used Only for the Macs native Inputs & Outputs)
Still no Joy
Old 03-10-2014, 03:48 PM
jeffro's Avatar
jeffro jeffro is offline
Just closing the loop here... I found Michael's support case which shows that creating a new User Account solved the problem.
This has been added to the KB:
http://avid.force.com/pkb/articles/e...en-Rack-Editor
linkedin
Old 06-12-2014, 01:46 AM
Frankee Frankee is offline
hi did anyone solve this problem??? I've tried everything stated above and in the avid reply.. any help would be much appreciated before i lose my [bleep][bleep][bleep][bleep] and start smashing stuff!! god i hate computers!
Initializing midi engine on 12.6 glogulus Pro Tools 12 1 11-05-2016 09:29 PM
Pro Tools Initializing Audio Engine Error kdro Pro Tools 12 10 08-14-2015 01:12 PM
Eleven Rack Editor Installation Error Haloll Eleven Rack 2 08-08-2015 06:44 PM
PT10 "sees" Eleven Rack as playback engine only (no editor window,embedded rigs,etc) locust_tree Eleven Rack 4 12-08-2014 03:16 PM
