Fast track pro: signal on output 2 while output level at 0
I'm using Fast track pro, driver 1.9.4, on mac os X 10.9. I have a set of krk monitors connected to unbalanced output 1&2. When I set the output level knob to position 0 (no output), with the mix knob full right (no input monitoring), I'm still hearing sound on output 2... When I turn the output level knob to the right, I begin to hear sound on both outputs.
Is that expected ? Thanks for your help. |
Re: Fast track pro: signal on output 2 while output level at 0
Does this happen on headphones as well? If not it's likely faulty hardware and likely not worth repairing. First unplug anything else connected to any of the other outputs on the interface. Then swap the L/R monitors with output 1 and 2 and confirm the problem stays with output 2. it is probably worth checking the IO is not messed up in Pro Tools. I assume you are using Pro Tools, if not speak up. With the Fast Track Pro selected as the playback engine create a new empty session. Go to Setup>IO and on each page (input, output, bus) click the default button. Now create a new stereo audio track. Drag one of your favorite iTunes audio file onto that track and play it back and play with the output knob on the interface. If the level on output 2 still remains too loud or the whole output is "off center" then your interface is likely faulty (and likely not worth repairing). If you are handy with a soldering iron etc. then the obvious thing to check is whether this output level knob is a simple double ganged pot. If so it may just need replacing or some gentle abuse. |
Fast Track Solo - no output | Elnico50 | FireWire & USB Audio Interfaces (Mac) | 0 | 12-17-2013 05:01 PM |
No output at all with my fast track | b52ravens | Pro Tools SE and Essential (Mac) | 4 | 12-30-2010 05:13 AM |
Fast Track output problems | ProdigalMedic | Pro Tools SE and Essential (Win) | 0 | 01-02-2010 03:51 PM |
No record level signal : Fast Track Pro, Pro Tools M-Powered 8 | mrmatter | Pro Tools M-Powered (Win) | 8 | 12-18-2009 10:32 PM |
Signal level decreases when output to bus for sub-mixing. | The Harvest | Digidesign Hardware & Software | 5 | 04-07-2009 11:49 AM |
