Old 07-20-2012, 03:20 PM
subwoof subwoof is offline
Default Neyrinck SoundCode LtRt
Anyone using Neyrinck SoundCode LtRt? I am evaluating it to replace Dolby Tools for making LtRt's.
My normal workflow with Dolby Tools is to buss the 5.1 mix stems to it (after some creative bussing to get the 5.1 tracks down to LCRS), then encode the stems into DX, MX, FX, and FO LtRt's, as well as making an LtRt of the printmaster and M&E. Those encoded signals go to stereo record tracks.
My question is, in setting up SoundCode LtRt to encode the 5.1 stems and printmaster, should I select "Surround Stereo LtRt (5.1) as the plug in type? When I go to instantiate the Soundcode plug-in on 5.1 aux tracks, I have the following options: "Surround Stereo LtRt (5.1 stereo)" or "Surround Stereo LtRt (5.1). The user guide is vague which to use as a TDM plug in.
Any wisdom out there on this?
Michael McDonough, M.P.S.E.
Michael McDonough Sound Design
Old 07-20-2012, 06:13 PM
minister's Avatar
minister minister is offline
Default Re: Neyrinck SoundCode LtRt
I have used the Neyrinck SoundCode LtRt (as part of the Dolby E package) successfully. You can do it as an offline, faster-than-realtime option. However, he provides no decoder. You can't mix with it. Hang on to Dolby Tools.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 07-20-2012, 07:53 PM
cjguitar cjguitar is offline
Use the Soundcode Stereo LtRt (5.1 to stereo) configuration, as you will be going from the 5.1 mix to a stereo LtRt and record the output of that. You'll find the Nyrincks plugin is so much better than the Dolby plugin.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 07-20-2012, 09:24 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
I use it to encode PLII from my 5.1, make sure you use it as DSP (TDM in my case) not Native. Native has 60ms of delay which delay compensation wont handle.
That means a lot when you're printing 5.1 LTRT, and M&E LTRT, at the same time printing to tape.
IMDB
Old 07-21-2012, 05:00 AM
garret garret is offline
Check out the minnetonka plug in. It lets you decode in real time so you can mix through it and hear the results.
Old 07-21-2012, 05:36 PM
kd_special kd_special is offline
I have listened to my stereo mix vs my LTRT mix though the dolby decoder SDU4. Ad I make my LTRT files with surcode by minnetonka. And I don't know if its just me or the shows I work on by my stereo mix sounds better when its decoded.
however most shows I work on are reality TV so its not like the is LS RS information besides music in these mixes. So for the past while I have just given my stereo mix as my LTRT.
The only thing I did notice is that when I bring the LTRT File made from my 5.1 Mix in Surcode into Pro tools. Put it back to back on matching tracks and look at the wave forms they seem to be at the same level and the meters show that too. However when I put them through the SDU4 the LTRT file is like 3 db louder general dialog/mix wise. So the LTRT encode must do some kind of magic.
kd
Old 07-21-2012, 07:15 PM
dr sound's Avatar
dr sound dr sound is offline
Mike,
Get the Neyrinck and use it to encode, use the Dolby to monitor the decode.
The Neyrinck has way more headroom then the Dolby Tools.
While I hate making an Lt/Rt if I have to I only use the Neyrinck.
http://www.neyrinck.com/en/products/...de-stereo-ltrt
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 07-21-2012, 07:32 PM
lexaudio lexaudio is offline
can you still buy the dolby plugin? I suppose you can, but will it decode PL2?
Neyrink needs to make a decoder, but I like the plugin more than the dolby.
Old 07-21-2012, 11:13 PM
Not sure if this does it all.
http://www.minnetonkaaudioshop.com/ATBM
But if it can decode, it is definitely cheaper than Dolby and LtRT Nryrink.
There is a demo so check it out.
Old 07-23-2012, 09:13 AM
Thanks everyone for your comments. It must be a marketing thing that keeps Dolby from updating and modernizing Dolby Tools to go past TDM versioning. After all, Dolby Pro Logic is a pretty old home theater format, and 5.1 is the thing in TV now. Maybe someone from Dolby could comment.
HTML code is On
FS: Sonic NoNoise and SoundCode Stereo LtRt plug-in mgoorevich Buy & Sell 2 09-22-2013 01:28 PM
Neyrinck SoundCode zzstation Post - Surround - Video 3 12-05-2012 11:24 AM
Neyrink SoundCode LtRt new version Cryos Pro Tools 10 2 10-04-2012 08:59 AM
Bug? Neyrinck soundcode folddown with hd2 FilterDecay Pro Tools TDM Systems (Mac) 2 04-08-2010 09:12 AM
Neyrinck SoundCode Dolby E emf1138 Post - Surround - Video 8 01-02-2008 06:35 PM
