Old 06-30-2012, 10:49 AM
hotgravy hotgravy is offline
Default Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8
Hello!
I have a strange yet consistent issue with my Pro Tools LE 8/Mbox 2 Mini setup.
I'll finish working in a session and close down Pro Tools. When I go to reopen Pro Tools in either that same session or any other one, create a new track and record enable it then the db meter peaks into the red and there is loud distortion on the track. This will happen no matter how many tracks I open. If I shut down Pro Tools and physically unplug the connector from the back of the Mbox 2 Mini that connects to the USB port on my Mac Mini and plug it back in I can then restart Pro Tools and the issue is gone.
Basically, every time I start a new Pro Tools session I have to unplug the Mbox and plug it back in again. That signal peak happens every time I don't unplug and replug the Mbox 2 Mini without fail. It's not a major issue but seems like I shouldn't have to do that each and every time I start up a session.
Info on my system and setup are below. If anyone has any ideas I'd be grateful to hear them.
Thank you!
Mac Mini
Mac OS X
Version 10.6.8
Processor: 2.4 GHz Intel Core 2 Duo
Memory: 2GB 1067 MHz DDR3
Digidesign Mbox 2 Mini
Pro Tools LE 8 - Version 8.0.5
Connected to back of Mac Mini via 6 foot USB cable (have tried various cables with same effect)
No other peripherals.
Meter Peak Hold, please! Doctor Faust System 5 0 10-20-2010 12:52 PM
Peak meter not responding? luqiao Pro Tools M-Powered (Mac) 3 12-26-2009 03:33 PM
which peak meter? evs Post - Surround - Video 8 09-04-2008 09:48 AM
volume/peak/delay meter Cammo2009 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-14-2004 11:16 PM
LED METER PEAK HOLD Gaffer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 02-19-2002 10:07 AM
