Old 03-18-2012, 03:20 AM
Rune Thuelund Rune Thuelund is offline
Default Copy/Paste plugin automation
Hi all.
How do I copy plugin settings from one eq to another on the same track? For example: I have two digirack 7 band eq's with different automation settings on one track, but I only want one. So I was thinking that I just copy/ paste the automation data from one to another since the two plugins are the same.
Does it make sense?
I am on Pro Tools 9 HD2 with command8
Old 03-18-2012, 03:28 AM
clusterer clusterer is offline
Default
Why would u have same settings on both eqs?
G. Rasek - recording engineer - www.overdub.at - european VO talents via source-connect - PTHD
Old 03-18-2012, 03:31 AM
lexaudio lexaudio is offline
Default Re: Copy/Paste plugin automation
Open the EQ you want to copy.
On the track with that EQ, place your cursor where your EQ setting is what you want to copy.
Shift+Command+C
Open the EQ you want to copy to.
Select in the project window the range you want to paste to.
Shift+Command+V
I think you might have to Write to All after you paste.
Old 03-18-2012, 03:34 AM
Sorry. I have two eq's with different settings on the same track, but I want to copy settings from one to another so that i only have one eq handling all eq on the track
Old 03-18-2012, 03:42 AM
I can't seem to make it work the way you describe it lexaudio. If I do it like that all the automation data on the eq I paste to changes to the setting from the copied on the entire track.
Old 03-18-2012, 03:47 AM
You need to select a range you want it copied too. Like from from minute to two minuted and write to all
Old 03-18-2012, 03:56 AM
Ok.
So I paste first (to a selection) and then write to all?
Old 03-18-2012, 06:06 AM
I have tried for a while now, but no luck.
Any ideas as to what I could be over looking? A setting or something...
Old 03-18-2012, 07:23 AM
cananball cananball is offline
Not in front of Pro Tools right now but can you bring up the eq automation lanes and simply select the automation parameters you want to copy one at a time and copy to the new eq and possibly write to selection?
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 03-18-2012, 08:29 AM
Default
I'd save the settings from one eq and just select this setting in the second eq.
HTML code is On
How to Copy/Paste Automation BriSarge Getting Started 1 07-01-2013 04:39 PM
Can't Copy and Paste Automation shameusf Pro Tools 10 3 05-25-2013 08:08 PM
Automation copy and paste on 10.3.2 YYR123 Pro Tools 10 2 04-16-2013 09:13 PM
How to copy and paste automation? bad jitter Pro Tools 9 5 08-12-2011 07:11 AM
Shuffle doesn't shift volumes - copy & paste doesn't copy automation marcnyc Pro Tools TDM Systems (Mac) 2 03-12-2010 12:46 AM
