I am running Pro Tools 9 with a Zed R16 firewire mixer on Windows 7.
Whenever I try to playback or record, the transport blinks the stop and playbutton for a second, then the word "pause" appears in green at the bottom of the screen and then it stops. No playback or recording I have read some other threads related to earlier version of Pro Tools but could not find a reference to this problem on Pro tools 9. The wierd thing is it was working for about a month, and now it is not. Did not install any plugins or software. This sucks. |
Its a bug, set your rtas processing cores to a different amount, select ok, then change it back. Or simply change the maximum percent of cpu usage.
Nick
Core i7 920 OC'ed @ 4.0 GHz (200 X 20) 12 GB Patriot Viper Extreme Asus P6T OCZ Agility 64 GB SSD Hitachi 1TB 32 MB HDD WD Caviar Black 500GB Saphhire HD 5850 3 x 20" monitors Eleven Rack w/ ERXP Fender Super Champ XD Marshall JCM2000 DSL100 Silver Edition W/ Silver Jubilee Cabinet |
OK, went to setup-playback engine and changed "host processors" (is that RTAS processing core?) and then changed back. Also changed "CPU usage limit" (is that maximum percent of cpu usage?) an changed back.
neither worked. |
UPDATE: I reinstalled and now it works. WTF!
OK, problem has returned even after the reinstall and update to9.0.1. Now,there is one session that causes the problem, but others do not.
Actually, this is how it started before, then seemed to spread to all sessions. Is this even possible? |
Try trashing prefs and databases then.
Nick
same problem. very very annoying. sure glad im not recording a band,
that would be fatal ![]() i changed from logic to my new protools 9 about 1 month ago and besides of a few crashes everything was ok so far. now this strange problem occured. no play. no nothing. just the bling bling no matter what i do. i have a newer black MBox and even the new Protools 9.0.2 Update. Still not working. A new blank Session is playing but if i open (from there on) the Sessions that worked just yesterday, they dont. Tried the IO default. didnt work. I read of this Problem with dates long time ago already in earlier versions. As i tried to change the Buffersize, and then back again, Protools completely hangs and does nothing even after 15 Minutes, so i have to interrupt it manually. The whole Session actually acts pretty strange. As i tried to remove Plugins it was taking wayyy to long. somethings wrong.. looking forward 4 the true solution.. |
Trying to Get Around the PLAY/PAUSE Bug | Kbiastre | macOS | 0 | 03-12-2012 02:26 PM |
What Did I Do? Play/Record has a pause .... | Craiger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 08-02-2009 03:43 PM |
PT8-Goes into pause, not play | original_min | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 34 | 01-14-2009 03:03 AM |
Stuck in Pause - Can't play or record | davegilliss | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 08-15-2005 10:02 AM |
Play and Pause Together? | LeonD | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 04-15-2004 10:55 AM |
