Old 11-21-2010, 07:33 AM
basslik's Avatar
basslik basslik is offline
Default help please PT9
I updated to Snow Leopard 10.6.3, then installed the combo update here Mac OS X v10.6.5 Update (Combo),
then installed the audio device drivers from the disk, then pro tools, as states in the manual, then I installed the demo as it suggests to make sure it's working but it says lost communication with the hardware, increase buffer, but it did load the demo , just can't play it back, and my 003 console says offline?, WHY ME (lol)
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
Old 11-22-2010, 01:42 AM
Meads Meads is offline
Default Re: help please PT9
Checked playback engine for which hardware is supposed to be used?
Something wrong with your firewire port/bus?
iMac Pro
- MacOS 10.14.6
- Pro Tools U HDN 2019.6
- Avid HD Omni + HD I/O 8x8x8
- C|24 | S3 | Dock
Old 11-22-2010, 07:22 AM
Did you install the separate 002/003 drivers?
Old 11-22-2010, 07:00 PM
basslik's Avatar
I installed the software update from apple (BAD) I know, I did by accident, anyways my PT9 boxed version came with device drivers, and installed the 003, but I did download the combo update, but didn't install it yet cause I already installed the APPLE update, is it too late to install the combo?
Old 11-22-2010, 07:45 PM
Bender Bender is offline
Do you have the 003 selected in the playback engine.
Old 11-22-2010, 07:56 PM
basslik's Avatar
Will check that out bender, thank you all, and give you folks an update, also whats the good feedback on the ones using PT9?
Old 11-22-2010, 09:43 PM
sunburst79 sunburst79 is offline
FWIW my MBP which I hadn't been using with PT for quite some time installed the software update and PT would not launch. I repaired the disk permissions and ran the Combo Update and it helped.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-23-2010, 05:43 AM
basslik's Avatar
I'm, shocked that there is no sticky keys or any kind of replies from from DIGITECH SUPPORT regarding PT9?, sunburst is it to late to install the combo after I already installed the the regular update from APPLE?, thanks
Old 11-23-2010, 07:10 AM
Its always been normal procedure to run the Combo Update instead of the Software update on the Mac when it comes to updating the OS.
You should be able to run the Combo Update after the fact. I was. Check your disk permisions when done.
Scott
Core 2 Specs Page
Old 11-23-2010, 05:48 PM
basslik's Avatar
Thanks, intend to do that. peace
