Old 10-05-2010, 07:09 PM
angeleda angeleda is offline
Default problem detected with audio clock. check that your clock source and sample rate are c
Hello...I recently purchased Pro Tools 8 LE and Digi 002 the rack, not the one with the built-in mixer... I installed everything, and also followed the optimization guide... And yet im getting errors all the time... The most common one is the
problem detected with audio clock. check that your clock source and sample rate are correct
Which is getting very irritating. At first i tried using some of the instruments such as Xpand and was working fine even though i didnt try recording... as soon as i tried to record, though, some test sounds in a stereo track through the mic in ports of my 002 it gave me the error that i mentioned above followed about a missing recording deadline (cant remembere exactly).
Also, the new problem now AFTER optimizing, is that by the time i creat a new track (its a stereo audio track), the whole things DIES AND FREEZES :S
Please tell me if my hadware has something wrong that could be affecting my 002's performance...
SiSoftware Sandra
Computer
Model : System manufacturer System Product Name
Workgroup : WORKGROUP
Host Name : MusicProduction
User : Music Production
Processor
Model : Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz
Speed : 2.83GHz
Cores per Processor : 4 Unit(s)
Threads per Core : 1 Unit(s)
Type : Quad-Core
Integrated Data Cache : 4x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size
L2 On-board Cache : 2x 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing
Computer
Mainboard : Asus P5N-D
BIOS : Phoenix Technologies, LTD ASUS P5N-D ACPI BIOS Revision 1101 05/18/2009
Bus(es) : X-Bus PCI PCIe IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support : No
Multi-Processor Advanced PIC (APIC) : Yes
Total Memory : 4GB DIMM DDR2
Chipset
Model : nVidia C55 Host Bridge
Front Side Bus Speed : 4x 333MHz (1.33GHz)
Memory Bus Speed : 2x 400MHz (800MHz)
Memory Module(s)
Memory Module : Golden Empire CL5-5-5DDR2800 5 2GB DIMM DDR2 PC2-6400U DDR2-800 (5-5-5-15 3-23-6-3)
Video System
Video Adapter : NVIDIA GeForce 9800 GT (112 SM4.0 1.4GHz, 512MB DDR3 2x900MHz, PCIe 2.00 x16)
Graphics Processor
OpenCL Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 495.6MB 2x900MHz)
CUDA Processor : NVIDIA GeForce 9800 GT (112SP 14C 1.5GHz, 495.6MB 2x900MHz)
Compute Shader Processor : NVIDIA GeForce 9800 GT (112SP 1.4GHz, 495.6MB 2x900MHz)
Storage Devices
Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache) : 466GB (C:) (F:)
Generic Flash Disk 4GB (USB) : 4GB (E:)
TSSTcorp CDDVDW SH-S202J (ATA66, DVD+-RW, CD-RW, 2MB Cache) : 6GB (D:)
Logical Storage Devices
System Reserved : 100MB (NTFS)
Removable Drive (E:) : 4GB (FAT32) @ Generic Flash Disk 4GB (USB)
Hard Disk (C:) : 58GB (NTFS) @ Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
Data (F:) : 407GB (NTFS) @ Hitachi HDP725050GLA360 (500.1GB, SATA300, 3.5", 7200rpm, NCQ, 15MB Cache)
3.5" 1.44MB (A:) : N/A
Pro Tools LE 1 (D:) : 6GB (CDFS) @ TSSTcorp CDDVDW SH-S202J (ATA66, DVD+-RW, CD-RW, 2MB Cache)
Peripherals
LPC Hub Controller 1 : ASUS MCP51 LPC Bridge
LPC Legacy Controller 1 : ITE IT8718F
Audio Device : ASUS MCP51 High Definition Audio
Audio Codec : Realtek Semiconductor 883 High Definition Audio
Audio Device : Creative Labs Sound Blaster X-Fi Fatal1ty
Serial Port(s) : 1
Parallel Port(s) : 1
Disk Controller : ASUS MCP51 Parallel ATA Controller
Disk Controller : ASUS MCP51 Serial ATA Controller
USB Controller 1 : ASUS MCP51 USB Controller
USB Controller 2 : ASUS MCP51 USB Controller
FireWire/1394 Controller 1 : ASUS VT6306 VIA Fire II IEEE-1394 OHCI Link Layer Controller
SMBus/i2c Controller 1 : nVidia MCP5+ SMBus 1
SMBus/i2c Controller 2 : nVidia MCP5+ SMBus 2
Network Services
Power Management
Mains (AC) Line Status : On-Line
Operating System
Windows System : Microsoft Windows 7 Ultimate 6.01.7600
Platform Compliance : x64
Performance Tips
Tip 2546 : Large memory modules should be ECC/Parity.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
Thanks
Problem detected with audio clock. Check your clock source and sample rate. sleeptalken Windows 7 08-10-2021 01:17 PM
Problem detected with audio clock. Check clock source and sample rate are correct mongrel8686 Third Party Interfaces 11 08-01-2013 08:42 PM
Problem detected with audio clock. Check that your clock source and sample rate are c Solow1nonly 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-06-2011 08:22 PM
Error: "Problem detected with audio clock. Check that your clock source and sample... mongo_man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 05-01-2010 06:08 AM
"Problem detected with audio clock. Check that your clock source and sample......... ASD15 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 16 03-26-2010 03:40 PM
