Old 08-20-2010, 12:23 PM
tobias bluth tobias bluth is offline
Smile cannot create fades
hello everyone i got a very annoying problem with writing fades to audio files.every now and then protools do not let me write a fade to an audio file nor with the smart tool or the mouse cursor and the edit-fade-command.this happens randomly but often and it is really annoying as you might can imagine.i encountered that behaviour for no apparent reason even when i created dozens of fades in the same session and on the same day.i would really appreciate any ideas,solutions or workarounds.thank you in advance.
Old 08-20-2010, 12:46 PM
Stig Eliassen's Avatar
Default Re: cannot create fades
A crossfade can't be longer than the region boundaries. If two whole-file audio regions are butted together, a crossfade can't be made. There's simply no audio after the region end of the first region, or before the region start of the second region, thus making a crossfade impossible.
Is this what's going on?
Old 08-20-2010, 02:22 PM
no not really, i encounter this problems with simple fades not crossfades
Old 08-21-2010, 08:40 AM
Nick Camaron Nick Camaron is offline
Location: Somewhere in the vicinity of Alpha Centauri, MW
Please specify... so many possible scenarios..
Machine? RAM..? Version?
Any error messages? Whats the status in the task window?
Old 08-23-2010, 01:33 PM
mac osx 10.5.8 2quadcore 10gb ram,pt le 8.0.1.digi 003 which i am working on for mixing and finalizing,digirack 002,mbox pro.
no error messages,comes out of the blue.never had that before pt 8(im there since 6.7).thought maybe the problem will going away after updating to 8.3,but whilst reading how many users want to revert to older versions due to the fact that more bugs causing misfunction than before i will keep my hands of updates for a long timee
Old 08-23-2010, 01:55 PM
Slim Shady Slim Shady is offline
Have you done everything in the General Troubleshooting thread?
If that doesn't work, I'd try some Teamocil.
Old 08-23-2010, 09:34 PM
with pt i found myself troubleshooting quite often...
Old 12-08-2010, 12:25 PM
scottleo14 scottleo14 is offline
Hey I also have a problem with creating fades, but when i highlight the region an press command f nothing even happens? I have also tried going to "edit" in the top window, and the "create fade" icon is grey, meaning I am unable to select this. I am using Pro tools SE, a version a recieved with buying my M-Audio MobilePre, and im wondering if I am able to create fades with this version. Btw im using a Macbook Pro.
If there is anybody willing to help me that would be greatly appreciated.
Old 09-10-2011, 09:24 PM
MixerGuy MixerGuy is offline
did anyone figure out how to fix this?
just curious
Old 04-16-2012, 01:56 PM
stelomax555 stelomax555 is offline
Hi All,
I have also had a problem with creating new fades. Every time i try to create a new fade it is just a white block. There are already plenty of working fades in this particular session and for some reason it is only in this session I am having this problem.
Create Fades not selectable? Earl D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 09-25-2011 04:19 AM
create fades batch fades issue pt le theom Tips & Tricks 4 07-24-2006 09:46 PM
Can't create fades while in play (6.4) DSSR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-08-2005 03:00 PM
How to create fades rha Digidesign Hardware & Software 1 03-24-2002 03:09 PM
Can't create legal fades Hal Knapp Pro Tools TDM Systems (Mac) 0 12-30-1999 06:10 PM
