Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-16-2009, 01:04 AM
crustn crustn is offline
Default Pro Tools 7.4.2 on Mac OS X 10.5.6: Installation failed
Hi everyone,
I know DigiDesign says Mac OS X 10.5.6 is not tested with PT m-powered 7.4.2 but I've read in different Threads that it works.
Unfortunately I've upgraded my iMac to 10.5.6 BEFORE installing Pro Tools. Now installation fails!!!! The Setup Wizard starts normally and freeze directly after beginning of the installation ('start installation script' written under the progress bar). Then nothing happens and I have to kill the application.
Same thing when I try to uninstall with the uninstall application. I even need to restart my mac by holding down the on/off button.
Anybody have the same problem?
DigiTech Support, any idea???
I don't want to downgrade may mac!!!! Please help!!!!
Thanks
crustn
Old 01-21-2009, 10:57 PM
yellowjacket yellowjacket is offline
Default Re: Pro Tools 7.4.2 on Mac OS X 10.5.6: Installation failed
With the 7.4.2 installer you downloaded, run the uninstaller and do a Clean Uninstall (even if Pro Tools is not even installed). Then repair your disk permissions in Disk Utility. Restart your computer, and then try to install again.
Old 02-27-2009, 01:46 PM
Ris2001 Ris2001 is offline
Hmm.
I am having a similar problem with installation.
After installing audio interface (Fast-Track Pro) and its drivers, I have tried to install M-Powered 7.4.2.
I get a little further, but when the installer reaches the "Digi Rack Plug-ins" portion of the install, it fails, giving me this message:
Installer could not install some files in "/".
Contact software manufacturer for assistance.
I've got a message in with Digidesign support, so we'll see. I did try the uninstall/repair permissions solution posted above, but I did not help in my case.
Anyone out there with some bright ideas for resolving this issue?
Old 03-07-2009, 08:41 PM
peoute peoute is offline
I am experiencing the exact problem. I'm going to try the suggestion above, but does anybody know if it works, or what does fix it?
Thanks!
Old 03-07-2009, 09:22 PM
Update: I repaired disk permissions and I attached the iLok during the install attempt, but still had the exact same problem.
Old 03-09-2009, 08:35 AM
DigiTechSupt's Avatar
http://www.digidesign.com/index.cfm?...&categoryid=34
Avid Audio Tech Support
Support FAQ
Old 04-17-2009, 06:23 AM
Hi Digi Tech Support,
unfortunately it still doesn't work for me. Any other idea?
PLEASE HELP!!!!!!
It's very embarassing. I had to create a new start up disk with OS 10.5.4 only for Pro Tools :-(((
Old 04-17-2009, 01:35 PM
Have you tried installing from a different administrator account yet? If not, please try it...
Support FAQ
Old 05-08-2009, 02:45 AM
Hi DigiTech,
thank you soooo much!!! That was the problem. I created a new administrator account and now installer works.
Pro Tools 10.3.2 Problem! The Installation Failed! alfaholic macOS 14 11-29-2018 01:45 PM
'Installation Failed' installing Pro Tools MP 8.0.2 on OS X Lion FuryMuso Pro Tools M-Powered (Mac) 3 06-03-2012 03:12 PM
Installation failed!! dkean Artist Series 1 12-24-2010 05:00 PM
Pro tools 8 (m-powered) failed installation. justin19153 Pro Tools M-Powered (Win) 1 07-20-2009 07:04 AM
Installation Failed Tamlin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 03-04-2009 01:18 PM
