Old 12-09-2008, 01:25 PM
coronos coronos is offline
Default Higher simultaneous recording track count in 7.3
I've searched for info on this topic, but haven't found much. Apparently the main thread that dealt with this issue has been deleted. (http://duc.digidesign.com/showflat.p...part=1#1124396)
The bits and pieces I've taken from what I've read basically indicate that in PTMP 7.3, the 18 simultaneous recording input limitation was overlooked, and the limit was actually 32 tracks. I'm not sure whether it was in 7.3, or if 7.3.1 was the first version with this "bug."
My question is, what was the first release to close this oversight? Was it in one of the CS releases, or was it not until 7.4?
I bought 7.3 just before 7.4 was released, so after I installed it, I applied the free upgrade before I knew about the limitation lapse. Now I'm re-installing 7.3 to get the extra tracks, but I want to know how far I can upgrade without losing them.
Thanks.
Steven
Old 12-14-2008, 12:09 PM
scoobydoo scoobydoo is offline
Default Re: Higher simultaneous recording track count in 7.3
7.3.1 up to cs3 I believe. Also I never saw anybody confirm it worked on the PC side. There's lots of debate on that.
I'm out of luck because my hardware requires 7.4 and I'm on windows.
You gotta get it in the mic!
SATA or Firewire 800 for higher track count? BigEvil Pro Tools TDM Systems (Mac) 7 01-17-2011 01:39 AM
Trackball response slows down with higher track count QuickPuppy ICON & C|24 0 08-02-2007 01:34 PM
8meg drive buffer=higher track count?? Nitronick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 04-17-2003 11:32 PM
Eighteen track simultaneous recording dBHEAD 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 01-31-2002 02:57 PM
Higher Track count for ProTools Le??? NuBus General Discussion 7 07-21-2001 11:48 AM
