Old 07-02-2006, 09:46 PM
James Kent James Kent is offline
Default Midi Output on Projectmix IO w PT 7 M Powered
Apologies, am a new user on Pro Tools with the M-Audio Projectmix IO and Pro Tools MPowered. I don't understand how to route the Midi in from my Roland JW-50 keyboard to the output. I have a MIDI track setup, have the input recorded on the track and can see the track input meter registered. When hit playback, the MIDI track is always silent. If choose External MIDI in the output button on the track view, it will play through the Keyboard amp using the 1/4 output from the back of the keyboard, but no choice will get the signal out through the project mix IO. Assume it is related to the channels and output mapping, but don't see any MIDI channel mapping, just numbered channels.
Help... I'm just now figuring this beast out...\
K
Old 07-02-2006, 10:33 PM
Default Re: Midi Output on Projectmix IO w PT 7 M Powered
Hi James
Are you trying to play your Keyboard with a Softsynth or the Patches contained within the Roland JW-50 itself?
For mapping your Roland, try: Setup>MIDI>MIDI Studio>Create>Manufacturer and Model (The Roland JW-50 should be listed) and assign the Input and Output Ports>Close.
...and if it's the latter of the two just previously mentioned, you'll need to route that Audio Output signal into one of the Analog Inputs on the ProjectMix.
filosofem
Aaron Mulqueen - 001 HD Native
Playback Midi Files in Protools 7.4 M-Powered and ProjectMix I/O dartveiga Pro Tools M-Powered (Win) 3 08-26-2008 02:15 PM
ProjectMix I/O with PT M-Powered 7.4 gone mad!!! gagaproductions Pro Tools M-Powered (Win) 0 04-12-2008 01:35 PM
MIDI Output? PT 7.4 M-powered - Need Help! n8rockerasu MIDI 5 02-02-2008 10:26 AM
MIDI Output? PT 7.4 M-powered - Need Help! n8rockerasu Pro Tools M-Powered (Win) 10 01-29-2008 07:40 PM
m-powered and projectMix meric Pro Tools M-Powered (Mac) 7 02-15-2006 07:49 PM
