Old 03-23-2006, 09:55 AM
dizzove dizzove is offline
Default NEO ACCESS ERROR
I'm running PT LE 6.9.2 with Mbox on IMAC G5 and every time I try to close a session I'm getting the NEO ACCESS ERROR and can't close session.I have to force quit protools to close it. I've had this problem in the past and it was resolved when I unistalled and reinstalled PT. But not this time.Can someone please assist me with this.
Old 03-23-2006, 10:00 AM
webby webby is offline
Default Re: NEO ACCESS ERROR
Answerbase is a great thing -
This can be caused by corrupt Database files. To resolve this you need to delete the files so Pro Tools can recreate new files.To do this, first quit the Pro Tools application, then:
On a Mac:
There will be folder called "Digidesign Databases" at the root level of each volume (partition) on the system. Delete these folders on each volume.
Then go to: Mac HD / Library / Application Support / Digidesign / Databases / Volumes
and delete the contents of the Volumes folder.
On Windows:
Then go to: C:\ Program Files \ Digidesign \ Pro Tools \ Databases \ Volumes
C: is assumed to be the system drive. If it is not, replace C: with the appropriate drive letter.
neo access error Edo55 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-04-2006 10:06 AM
Neo Access Error palmer_jankens 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-31-2006 08:17 PM
Neo Access Error Calum M 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-24-2005 02:46 PM
neo access error mudflaps Pro Tools TDM Systems (Mac) 1 12-20-2004 11:04 AM
NEO access error????please ariel keshet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-28-2004 08:22 AM
