Old 11-09-2005, 04:46 PM
Gary Fitz Gary Fitz is offline
Default Crossfades?
I am mixing down a song for a 1st year university project. In the guitar track, the sound suddenly pans from left to right, creating a "click." I have been told that this click can be removed using crossfades. However, i cannot got it to work. Can someone please explain to me how to do this.I know ths request may seem a little stupid to some of you more experiencd pro tools technicans, but any help would be greatly appreciated.
Old 11-09-2005, 06:58 PM
minister's Avatar
minister minister is offline
Default Re: Crossfades?
some drastic panning automation moves can cause these problems. but did you check your volume automation as well? you may have inadvertently changed that automation drastically too.
one way to do this kind of move would be to split the guitar into two tracks, one left the other right. then cross fade between them, either with volume or crossfade files.
this is not a judgment, but i can't think of why you would want to do this. what are you trying to accomplish? maybe there is a better way to get your desired effect.
Tom Hambleton CAS
Ministry of Fancy Noises
IMDb
Undertone on Facebook
Undertone Custom Sound Libraries
"Groupable markers would be epochal!"
-Starcrash
Old 11-09-2005, 07:06 PM
JKD99 JKD99 is offline
Any volume or pan move, if you've made it occur instantaneously, will always cause a click. Try, with the pan graph displayed, making your breakpoints even 10-30 ms apart will eliminate the click and still sound "instantaneous" to 99% of your listeners.
hope this helps, good luck!
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Puget Sound on Facebook
Old 11-10-2005, 04:36 AM
Richard Fairbanks Richard Fairbanks is offline
As JKD99 points out, make sure your automation breakpoints are tilted lines, not vertical cliffs. A smooth 15 millisecond change will eliminate clicks on any material. Actually, 10ms is all you need, but I use 15 in case Pro Tools automation gets a little sluggish and misses the marks.
Looking at volume, or pan, or eq, or any automation change when audio is actually playing:
|__| = bad
\_/ = good
Call me by my real name, "Postman"
Old 11-10-2005, 05:43 AM
excellent graphics, Richard!!
well done
Joe Milner
Puget Sound, Inc.
Los Angeles
IMDB
Old 11-10-2005, 09:22 AM
Dan Pinder Dan Pinder is offline
He's kind of an ASCII stud.
Old 11-10-2005, 01:10 PM
Kelly M. Pieklo Kelly M. Pieklo is offline
That was the funniest thing I've read all day.
"I don't feel tardy." - DLR
Old 11-11-2005, 01:12 AM
tj_davies tj_davies is offline
Just asking,
are you sure the click derives from the crossfade or automation? Or is the clicking in the recording of one of the two tracks? If so you can zoom into the tracks and use the pencil to remove the click in the audio file!
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
HTML code is On
Help me with crossfades! HastyRichtardo Pro Tools M-Powered (Win) 3 04-26-2010 07:51 PM
PT crossfades? buckaroo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-30-2008 12:46 PM
CROSSFADES, CROSSFADES, CROSSFADES, CROSSFADES Jim Casey 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 05-25-2007 04:41 AM
Crossfades in LE 6.9 trackster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 06-27-2006 08:25 AM
Crossfades stut5 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-24-2002 03:23 PM
