Old 05-21-2005, 12:08 AM
tonicjeff tonicjeff is offline
Default OSX G5 Set Up Assistant and PT
Has anyone used this tool to migrate from g4 to g5? I just got a G5 dual 2.0 and I was thinking of just connecting my G4 as a target FW drive and using the migrate tool.. Will this work? Obviously with the exception of disc or challenge auths which I assume will have to be re done anyway.. thanks
hd accel 2
Pt 6.7cs8
G5 dual 2.0 (pending install)
2.5 gigs ram
firewire!!!!!!
Intel Nehalem 8 Core 2.26 w/10 gigs of Ram
4 internal sata drives (1 terabyte)
Magma Pci to PCIe 6 slot chassis
PT 8cs3
HD 2 Accel
1 Process Card
UAD quad
PT 8.0.1 cs 1
OSX 10.5.8
Ctrl 24
Old 05-22-2005, 06:38 AM
Drew Mazurek's Avatar
Default Re: OSX G5 Set Up Assistant and PT
i did it manually. drag and drop sessions and plug in folders, re-installed app. felt like the right to do and went off without a hitch.
www.drewmazurek.com
Los Angeles Studio seeking Assistant Engineers johnnyv Employment 1 01-13-2013 10:33 AM
London Audio Assistant job available! jahtao Post - Surround - Video 4 10-18-2011 04:33 PM
Assistant Engineers rates? barismanco123 General Discussion 4 10-29-2009 02:05 PM
Apple Setup Assistant to X-fer from G4 to G5 svsnyc Pro Tools TDM Systems (Mac) 2 04-20-2005 10:07 AM
Change Note Assistant potatohead Post - Surround - Video 5 09-05-2003 08:49 PM
