Old 04-15-2005, 09:20 AM
morrisbrown morrisbrown is offline
Default Midi Beat Clock and looping
hi,
I have a problem when looping an 8-bar loop in PT and syncing an external drummachine. When the loop goes ones around and starts again, the drummachine looses the sync and stops ie. PT drops the midi beat clock.
Any idea if this a default setting and can it be changed somehow? In other sequencers like Live and Logic this works well.
Setup is a TDM system with 6.7.
Any help appreciated,
thanks,morris
Old 05-23-2005, 10:21 PM
maestro b maestro b is offline
Default Re: Midi Beat Clock and looping
I'm having the same problem with 10.3.9 (oops) and 6.7. I actually had to uninstall Quicktime 7 in hopes of resolving the problem, however, I still have the problem. I'm thinking of trying 6.9. I've seen some other post that make me believe that it might work. If not, I guess I have to wait for Tiger. Any suggestions would be welcome!
Slave MPC 5000 to PT9.06 via Beat Clock - timing drifts when looping headsup macOS 4 02-11-2012 12:22 AM
Pro Tools Slaved by Midi Time Code or Midi Beat Clock DarylBham MIDI 5 06-14-2009 01:55 PM
MIDI BEAT CLOCK STILL Bad on PT 7.1.1 alx002 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 29 12-10-2006 11:59 AM
Triton...is MIDI Clock difrnt than MIDI Beat Clock BookSix 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2006 12:24 AM
MIDI Beat Clock & Looping cjp76 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-26-2005 10:00 AM
