Mac OS X Non-Admin Account & Pro Tools 6.4
Pro Tools 6.4 Non-Admin Read Me
The following information is available as a downloadable PDF in the Technical Document Library in the Digidesign Support section of the website under Pro Tools 6.4 Read Me Documents. This document was created after the release of Pro Tools 6.4 and is not included with the 6.4 installers. Using Pro Tools with a Standard (Non-Administrator) Account on Mac OS X Pro Tools 6.4 on Mac OS X supports both administrator and standard accounts. Allowing Pro Tools to work with a standard account gives schools and other facilities with multiple Pro Tools users greater flexibility. It enables multiple engineers or students to work with Pro Tools while limiting their ability to install software or access local disk and server locations that should remain restricted. Installation and Operation Installation and operation of Pro Tools with a standard user account follows the same procedures that are covered in the Pro Tools Reference Guide, and other documentation. Keep in mind the following:
Users of standard accounts on Mac OS X with Pro Tools will be limited to saving sessions and audio files to folders within their Home directory. Existing folders in a User’s Home directory include:
A standard account user working with Pro Tools who tries to Save a Session, Save an audio file, or Save Session Copy In will encounter a gray Save button unless they choose to write the file or files to one of the locations listed above. Saving files and recording on an internal drive will work well for small to medium-sized sessions. For larger sessions requiring many tracks and higher sample rates, external Firewire or SCSI drives may be required. Users requiring external drive access will need to ensure they have Read/Write permissions set to use these drives if logged in using a standard account. Configuring a Standard Account for Pro Tools Users When setting up standard accounts for Pro Tools users, it is suggested that System Administrators set the Limits for the nonadmin account to “No Limits.” If the account is restricted, users will encounter further restrictions than those covered above when they try to:
Usage Limitations with Third-Party Plug-Ins Digidesign has become aware of some third-party RTAS plug-ins that do not allow users to be logged in with standard accounts on OS X due to issues with their copy protection. Several plug-ins by Native Instruments have this limitation. Native is working to solve this issue and has workarounds for some of their virtual instrument plug-ins. Opening a Session with a QuickTime Movie as a Standard Account (Non-Admin) User Can Prevent the Movie from Playing Back (Item #47053) If you open a session as a standard account (non-admin) user and you do not have permissions for the QuickTime movie file, Pro Tools will tell you that the movie file cannot be found and prompt you to relink. In the relink window, the movie can be found and Pro Tools will appear to relink to it but it will still not play back. For correct playback, make sure you have permission to use the QuickTime movie file.
Administrator Avid Pro Audio Community |
None Admin account recording | Graham wilde | Pro Tools M-Powered (Mac) | 0 | 04-29-2010 11:10 AM |
Pro Tools LE 7.1 crashing with non-admin account | blender | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-29-2006 09:06 AM |
Trick to using PT7 in 2nd admin account? | dmsaudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 12-01-2005 08:46 AM |
Mac OS X Non-Admin Account & Pro Tools 6.4 | Avid | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 06-25-2004 12:52 PM |
Mac OS X Non-Admin Account & Pro Tools 6.4 | Avid | Pro Tools TDM Systems (Mac) | 0 | 06-25-2004 12:51 PM |
