Old 06-14-2004, 11:05 PM
Cammo2009 Cammo2009 is offline
Default volume/peak/delay meter
After reading the manual I found out that the delay meter below the fader in the mix window will give you the delay in samples created by TDM plugins. Does this mean using RTAS plugins are not meant to incur a delay? The reason I ask is that I've been messing around layering compressed drumloops with the origonal uncompressed with varied results. With one plugin on one channel (in this case the BF76) it worked fine - but as soon as I put on another plugin I got comb filtering. The dealy meter said there was no delay.
Can anyone explain??
thanks.
Old 06-14-2004, 11:16 PM
Default Re: volume/peak/delay meter
Most RTAS plug-ins don't have delay.. some which use look-ahead buffers do... and they'll report a delay if the developer coded it.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Signal peak/distortion/db meter peak when recording enabling track on Pro Tools LE 8 hotgravy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-30-2012 10:49 AM
which peak meter? evs Post - Surround - Video 8 09-04-2008 09:48 AM
volume/peak/delay, delay shown in samples or ms? Ziko 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-29-2008 04:11 PM
volume/peak/delay indicator problem Zettt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-14-2004 09:24 AM
volume/peak/delay display Fave 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 04-21-2002 09:22 PM
