Old 02-23-2016, 08:35 AM
mikedocy mikedocy is offline
Default Voxengo Span finally available in AAX (free)
http://www.voxengo.com/product/span/
SPAN is a real-time “fast Fourier transform” audio spectrum analyzer AU, AAX and VST plugin for professional music and audio production applications. For the most part it was derived from Voxengo GlissEQ dynamic parametric equalizer and reproduces its spectrum analysis functionality.
SPAN provides you with a very flexible “mode” system which you can use to setup your spectrum analyzer preferences. You may specify Fourier block size in samples, FFT window overlap percentage, spectrum's visual slope. Beside that you can choose to display secondary spectrum of a desired type (e.g. real-time maximum, all-time maximum). Spectrum can be smoothed out visually for an easier examination.
SPAN supports multi-channel analysis and can be set to display spectrums from two different channels or channel groups at the same time. Spectrum's color can be chosen to taste.
SPAN also features output level metering with adjustable ballistics and integration time, K-system metering (including calibration K-system metering). SPAN displays level metering statistics, headroom estimation and clipping detection. Correlation metering is available as well.
Old 02-23-2016, 01:46 PM
Shan's Avatar
Shan Shan is offline
Default Re: Voxengo Span finally available in AAX (free)
What a surprise. Great to finally see this officially supporting PT on the AAX format!
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 02-23-2016, 01:56 PM
Sounds good. Surprising Voxengo still recommends using the fxpansion vst-RTAS wrapper considering fxpansion hasn't had that available for years.
Jack
QAPLA!
Old 02-24-2016, 08:23 AM
JCBigler's Avatar
JCBigler JCBigler is offline
I'm well versed in using an FFT analyzer such as Smaart or SIM to analyze the phase and EQ of a live PA system in a room.
How do you use this as a plugin and what benefit does it have in the mixing process?
Justice C. Bigler
www.justicebigler.com
Lenovo P50: quad-core i7-6820hq, 64GB, 2TB SSD, Win 10 Pro / Protools Ultimate 2023.6 / HD|Native-TB
2018 MacBook Pro: six-core i9, 32GB, 1TB, Monterey / Protools Studio 2023.6, / DVS / DAR, L-ISA Studio
Home/mobile: Focusrite Red 8Pre+HD32R / Clarett 4Pre
Road/hotel: Roland OctaCaputre / Apogee One
Old 02-27-2016, 01:22 AM
Alexiz Alexiz is offline
They probably haven't updated their website yet; but this is what they have mentioned in their tweet of some ten days ago (regarding their entire line of plugins, I guess):
Voxengo ‏@voxengo · Feb 18
We have updated our plugin development tools to include AAX64 plugin support. Future plugin updates will be compatible with ProTools 12+.
...and, yeah, I thought this was a bit odd too:
Old 02-28-2016, 08:52 AM
JuanPC JuanPC is offline
In PTHD9.0.6
Zooming Span all the way in dB, analyzing ProTools Pink Noise Signal generator, I could see aliasing/phase cancelation ripples @96KHz...
But...
The free VST MDA Pink Noise TestTone Generator... Was flawless.
Wrapped with FXPansion RTAS adapter.
PT signal generator ripple bug/problem was the same in Windows & OSX.
Old 03-01-2016, 04:30 AM
Given this (as quoted from above): Voxengo ‏@voxengo · Feb 18
would it be a stretch to think they'd also update Pristine Space to aax64 and OSX? I miss that ir reverb from my old Windows/Sonar days.
Jack
QAPLA!
Old 03-10-2016, 09:19 AM
had my first -error in ProTools HD12.3.1 since i installed SPAN... W7x64sp1
but ProTools continued to work OK, just a windows pop-up, clicked OK, and everything normal again.
Access violation occurred, unable to read location 0xFFFFFFFFFFFFFFFF
Old 05-05-2021, 09:48 AM
rbw rbw is offline
Hello, I am struggling to get Pro Tools First to find Voxengo Span. I was hoping it would be compatible - does anyone know if it isn't? I know PT should be version 12+
Old 05-05-2021, 10:08 AM
PT First can only use it's own plugins or those purchased through Avid store.
Jack
QAPLA!
HTML code is On
spectrum analysis with Voxengo SPAN. glamfolk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-26-2011 04:45 PM
life span of a dual gr 1.42 with PT? cajonezzz Pro Tools TDM Systems (Mac) 0 05-29-2006 01:11 AM
FINALLY 48 TRACKS AND FREE SYNTH Fresh27 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 71 02-10-2006 04:17 PM
RE: Finally A Decent Sound Input for ProTools Free! vf124 Digidesign Hardware & Software 0 11-14-2001 05:53 AM
PT Free R2 works (finally) on my HP Pavilion normg Digidesign Hardware & Software 0 12-29-2000 08:29 AM
