#51
Re: why is protools so spoiled in terms of it's OS enviroment and hardware profile ?
When you can remember your Protools Authorization number by interative installs it does not speak well for the quality of software currently being shipped or the QOS process prior to release.
Here's my current unstable situation: Brand new 003 Rack+ Factory shipped with PTLE 8.0.0314 i7 920 2.66MHz build ASUS PT6 deluxe mobo 6GB OCZ Gold 133MHz DDR3 500GB Segate 7200 rpm 1.5GB Segate 7200 rpm Pioneer 20X DVD Burner ASUS EH4350 VGA SIIG 2 port 400 TI Chipset 1394a Windows Ultimate SP1 I have not been able to find a stable combination for this setup with PTLE 8.0.0314. The PT system is good for one session after a fresh install which appears to work fine. Intermittently exiting and loading the same session will load or hang in reading perferences, DAE loading, or Initializing Globals. When it hangs it LUTHANC ( Locks up tighter than a ....) which took be while to figure out that the only way to get back machine control is dump power on the 003 Rack+ to generate an interrupt for a DAE error. There appears to be a total lack of error recovery in this software. The end user is never given proper feedback to possible errors or installation problems. It also appears that this product has no built in tracing or error logs to aid in trouble shooting or debugging. If as noted by Digidesign the TDM engine is prone to frequent problems relating to the hardware / software operating enviorment, why not log some error messages or write some trace files or at a minimum display an egg head message to the user. I have faithfully cannibalize Vista to PT's recommended settings. Still unstable. My first call to Digi support last night took 30 minutes to connect to a techinical support rep, which attempted to help me. His suggestions: 1) Pull all the 6GB of 2GB memory sticks and replace in an experiment to see if the memory was bad? I marked the sticks and tried all combination. Did not help running any of the three sticks in 2GB memory configuration. 2) Update the drivers to ASUS EH4350 video card. Did that still unstable. 3) Contact someone with a similar hardware set up on this forum and hope they can help. D O I N G__T H A T__N O W ! !_____H E L P ! ! Would like to get back to writing some tunes. Any tips or help would be greatly appreciated. regards gordon |
#52
You should start your own thread and provide the information provided in these two topic's:
Help us help you - what you need to know before posting! General Troubleshooting - Pro Tools LE on Windows (XP & Vista) Quote:
#53
#54
Hi Tom,
I did notice that most of the i7 users are running XP Pro SP3. I considered both and regret now the vista choice. My game plan for tonight will be XP Pro SP3 to see if can get a stable system. Regards, Gordon |
#55
I mean if PT (LE) users, working all day for (more or less) money in their studios, can come up with hardware specs, and trying out newer, faster, hardware - on spare time - I think maybe a great company like Digi should be able to spare one or two persons to do this as well. And to keep up fairly good with the performance step-ups happening every twice a year or so. I love PT, and I would love it even more if some of it's problems disappeared. Cheers, - J Ps. Why not build at least 4 different PCs inhouse in a varying price/performance range, up to i7 or other. Install, test, tweak OS, test, test, post exact HW specs and OS-tweaks. Keep these specs up to date as OS and hardware evolves. Possibly a ready made OS-image w drivers would help even more.
Digi 002 Mbox 1 Digi001 (retired to shelf) Asus P5K Premium v3, Q6600, 2x2GB Corsair Tyan Thunder n3600B (S2927A2NRF) 2xAMD OPTERON 2214 2.2GHZ Win XP Pro SP3 |
#56
Also provide case studies, of how this sytem was qualified including session testing constraints, steady state performance conditions. Case study should illuminate: long term steady state, vertical track expansion, horizontal time based expansion, robust usage of pluggins with compex automation laws I am hoping you have three classes... (01) Traditional post production (02) Intense music creation employing substantial midi and VI's (03) Scoring using many edits and sample based audio regions Vendor of this system, Rough order cost, and lead time. I am an electrical engineer and when we specify a system, our customer will drop us if we fail to verify that our proposed product does not meet the end users normalized performance requirements. Regards, KB |
#57
The DAE and PT was designed and made for DSP cards. It was never intended to be run natively. That's a big part of the problem right there. How they even got it to work natively at all is quite the engineering miracle. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#58
Just glad they did.
#59
Now that the source was discovered, I have a stack of 5 perfectly working Tyan motherboards collecting dust. Shane
#60
what is your power supply?? have you properly installed your video card, motherboard drivers? do you have the asus overclocking utility (cant think of the exact name) installed?? if so uninstall. but go over this then move your post over there. thanx
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
No hardware profile in Vista? What do you do? | scoobydoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-13-2008 07:47 PM |
Hardware profile confusion | Detuned6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 11-05-2006 02:44 PM |
Mac Enviroment Setup to Optimise Protools | DJ Pocky | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-19-2004 08:53 AM |
Hardware Profile Bug | leonardrock | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 11-15-2003 07:15 PM |
new hardware profile help | lovebone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 10-19-2002 03:08 AM |
