Old 07-15-2016, 05:19 PM
davemartone's Avatar
davemartone davemartone is offline
Default ELASTIC AUDIO Thumbs Down with Multi Track Drums
Hello All. Possibly someone can suggest a better way then what I have been trying for a few days.
I have been messing with multitrack drums and Elastic Audio quantize.
I have tried every algorithm with these and they all mess up or phase the top end of the cymbals.
I have found the best is to be on all the shell drums.. use RHYTHM... and on the Overheads.. room or far mikes use POLY.. Even with this.. When I check against a playlist that has no elastic audio on it... things are phasing with Elastic audio.
I have tried every combination with this and still came up with un satisfactory results. I am checking it in succession with Logic X Flex time using the Slicing option. This has WAY BETTER results... however there are no playlists to easily swap back and forth on...
Any suggestions anyone that has done extensive testing as I have.. I am coming up with a loss, and possibly will have to go and learn beat detective. Once again I am not comparing the both, just was trying to get Elastic Audio to work without top end phasing on the cymbals, hats etc. but have failed
Protools 12.5.1 HD
Logic X 10.2.3
El Capitan 11.10.3
Apollo 8 Quad Thunderbolt
I7 Mac Mini
16gigs Ram
1TB SSD
Old 07-15-2016, 05:43 PM
Shan's Avatar
Shan Shan is offline
Default Re: ELASTIC AUDIO Thumbs Down with Multi Track Drums
Unfortunately, that's your answer. I myself would never user EA on a multi track kit.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 07-15-2016, 05:51 PM
AlexLakis AlexLakis is offline
Easy. Use X-Form in Pro Tools 7.4. The iZotope Radius algorithm was set way better set in that version. Pro Tools 8+ X-Form = rubbish. Fix it, please, Avid, this is an easy fix on your end!
Old 07-15-2016, 07:06 PM
Shan's Avatar
+1. It certainly was!!
Shane
Old 07-15-2016, 07:22 PM
Well I guess we are mostly on 12.5.1 now.. Its too bad. In prince-able it works... but to the ears it just does not cut it.
Old 07-15-2016, 08:08 PM
edwinstar's Avatar
edwinstar edwinstar is offline
i'd suggest Beat Detective!
Gesendet von iPhone mit Tapatalk
Old 07-15-2016, 09:49 PM
EGS's Avatar
EGS EGS is offline
Waves SoundShifter.
Click for audio/video demo
Click for resume
Old 07-15-2016, 09:53 PM
soybalm soybalm is offline
Are you grouping the clips as opposed to grouping the tracks? Select clips and group(found in one of the menus), then do your quantizing trying Rhythm, Polyphonic or whatever. It'll probably still phasey but worth a try if you haven't grouped the tracks.
Dave Cournoyer-guitarist-project studio
Mac Mini late 2012, i7, Sierra
16GB PT10.3.10HD PT12.5.2
Apogee Mini-Me firewire.
Old 07-16-2016, 02:14 AM
midnightrambler midnightrambler is offline
Yes I had this discussion on here a few years ago with other users, though I can't find the topic at the mo
I also came to the conclusion that using Beat Detective results in much better fidelity (especially on the overheads track) compared to elastic audio, no matter what algorithm is used.
Old 07-16-2016, 06:05 AM
Stephen Bond's Avatar
Stephen Bond Stephen Bond is offline
This is going to cause problems. You need to group the tracks and use the same algorithm on each track or you will invite trouble.
Elastic Audio is far from perfect with many types of audio. I have used it on drums, even quite recently as it is far quicker than Beat Detective and easier to work with. However, the later usually yields much better results, certainly no phase issues! It of course has it's own difficulties.
Agreed with the other posters here. Avid, bring back the Elastic Audio of old (7.4?) with its stellar quality!
Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2
https://www.waves.com/r/djgsi6
Elastic Audio Glitches on Multi-Track Drums travista00 Pro Tools TDM Systems (Mac) 13 06-09-2008 02:11 AM
Problems with Elastic Audio on Multi-track drums O.G. Killa Pro Tools TDM Systems (Mac) 28 01-02-2008 01:34 PM
Pro Tools 7.4 multi track drums editing video Paulthe3rd Pro Tools TDM Systems (Mac) 1 12-08-2007 02:48 PM
How do i do use elastic audio across multi track drums... chucknkd 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 12-03-2007 02:46 PM
elastic audio on multi track drums... asdfg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-15-2007 04:47 PM
