#961
Re: i7 Builds - Specs and Results
bassist...deep pocketz anyone???!!! The Basschakra Lucid Soul Trip i7 Builds - Specs and Results HDNative | Omni | i7-3930K OC'd 4.0GHZ | ASUS X79 Sabertooth | 32GB GSkill DDR3 2133 ram | mo' stuff |
#962
Hey guys!
I am ordering all the parts I need. What is wrong with the heatsink and fan that comes with the i7 as stock? I noticed all of you buying the coolmaster for 50bucks.. is it really necessary? I rather buy an extra hard drive with the money. |
#963
Some people.
#964
Other folks are probably worried about high temps from overclocking. I'm sure the stock heatsink will work fine if you don't care about fan noise or overclocking. |
#965
#966
With a decent cooler its going to be easy to OC and still keep it cool and quiet.
The stock cooler's fan will ramp up earlier and even at full speed will not be able to reach the same OC freq. Even if it can handle the heat, a CPU that runs constantly at lower temps will likely live longer than the same CPU at higher temps. Same goes to RAM and any component for that matter.
i7 2600K @ 4.4GHZ -- Intel DP67BG B3 -- 8GB DDR3 1600 -- Crucial SSD PTLE 8.0.4cs2 -- DIGI 003R -- DV toolkit -- Waves 9 |
#967
I'm having an issue with my system.
I'm not sure if it PT related or just the machine. I don't use the machine for anything other than PT. So I can only say that the problem has only happened during PT use. 3 or 4 times now after launching PTle 7.1 MPT and getting into a session the machine will freeze. No mouse, no keyboard, no nothing. Frozen. I have to reset it to get going again. And so far resetting the machine has worked and the problem has yet to re-occur after this initial freeze. But I usually turn off the machine when not in use so every time I get into my studio the machine is just freshly started up. Has anyone else seen a problem like this?
Intel I7 920 Asus P6T Digi 002R. Command/8 PTLE 7.1 MPT www.clearspotrecording.com |
#968
i read tests on the stock cpu fan and they are not quite up to par. as everyone says, they are noisy and do not do a very good job and not recomended at all for oc'ing. the cooler is a under rated part in my opinion. the life of your cpu and other parts and dependant on it doing its job effectively and efficiently.
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
#969
#970
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Best Core 2 Series Desktops-Results and Specs | sunburst79 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2416 | 02-19-2013 07:49 PM |
new to pc builds | chazc080488 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 10-18-2011 07:10 PM |
any p45 builds | fofif5792 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 09-09-2008 12:47 PM |
OSX "builds" | Richard Barrie | Pro Tools TDM Systems (Mac) | 2 | 10-18-2004 08:37 AM |
