Pro Tools LE error question...H/W Buffer
Hi there..i am new here, and fairly new to recording in general...I have done hours of reading and searching the internet but can't figure out why this problem persists...I apologize if this has already been addressed...if so, and you can post the URL for a previous thread that would be appreciated...
the error is: "The operating system held off interrupts for too long. If thes occurs often, try increasing the H/W Buffer Size" Anyone know why i would keep getting this?..i have changed the buffer back and forth...it doesn't change anything...I have searched the internet, and found lots of people who seem to have this problem, but no solution... My computer has plenty of memory....it is a Dell Laptop w/Win XP, 2 gig Ram, brand new Dual core processor, etc... Is there some type of computer setting that I need to change?...I am perplexed on this one...it completely kills whatever i'm doing at that moment...even when i'm in the middle of recording tracks... BTW, I'm running ProTools LE 7.3, w/Mbox thanks! |
Re: Pro Tools LE error question...H/W Buffer
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
You may want to look at the Help us help you thread as well. |
Are you recording to a physically separate hard drive. In the case of a notebook, this usually means an external firewire drive. It is not recommended to record to the system drive or a partion of the system drive. The second drive should be at least 7200 RPM or as fast as possible.
Obsidian Dragon
MacbookPro14,3 - Intel Core i7 3.1 GHz, 16 GB MacOS 13.6.6 running Protools 2024.3.1 Mac Studio M1Max - 64GB MacOS 14.4.1 running Protools 2024.3.1 |
There has to be something wrong...my machine has more than enough power to run this...is there a setting or something that I'm missing?...I'm a pretty computer savvy guy, that is why this is so perplexing to me... |
I think I provided all the information necessary, if not please let me know....I know that this is a common problem with 7.3 LE....i searched the net and found many folks with the same problem, but can't seem to find the solution....my computer has more than enough power...i'm confused. |
This has been confirmed on a few laptop systems already. And the odd thing is, I can use my "other DAW" with the Mox Original and Mbox mini using the Digidesign ASIO driver...and it works like a dream without issues. Try that and report back. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Obsidian Dragon
I researched these topics deeply before building this computer, and I never read anything about a separate HD being required for it to work ..especially in it's simplest form...recording and mixing 2 or 3 tracks? I'm not being sarcastic in any way...i really just don't understand? Feel free to reply in computer speak...i understand the jive... thanks so much! |
1. Any error numbers 2. A Sandra or PCWizard report 3. A clear outline of exactly which troubleshooting steps you have or have not taken 4. A description of how you have everything configured - is the Mbox connected directly to the computer or to a hub? Which drive you were using for recording and playback (which you posted after further questioning), if you have any other peripherals attached, etc. The fact that you claim to have read both the posts I mentioned, yet have failed to provide the information requested in those posts indicates that it's more than likely you did not completely read or do everything in those threads. We see that all too often around here, which is why we have to be sticklers about details, details, details. Without them, it's difficult to troubleshoot properly since we can only base decisions on what you've told us (we can't actually see your computer, how it's performning, how everything is hooked up, etc). You also say "I researched these topics deeply before building this computer, and I never read anything about a separate HD being required for it to work ..especially in it's simplest form...recording and mixing 2 or 3 tracks?" Perhaps you missed this: <font color="#666666"> Performance Guidelines • Recording to the system startup drive is not recommended or supported • Although limited recording and playback of audio tracks may be possible using the startup drive, one or more separate dedicated 7200 rpm audio hard drive(s) is required for maximum performance and track count From the Pro Tools LE 7.3 Windows Laptop Systems Compatibility Page |
H/W Buffer Error (pro tools error -6104) Only 1 audio track running. | kieran.mia | macOS | 1 | 01-29-2013 01:39 AM |
Protools buffer error and upgrade question | wb249 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-27-2010 06:54 AM |
Another h/w buffer 6086 error question | grimorian | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 51 | 04-14-2010 08:00 PM |
H/w Buffer Error - Chipset/processor Question | GreyhoundG | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 04-06-2008 12:58 PM |
6085 buffer underun error question?? | shanabit | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 09-19-2007 09:12 AM |
