#31
Re: Plugin Delay Compensation
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#32
Shane
#33
I still believe in these times and in this competetive world the focus and goal should be put at :
FULL plugin delay compensation. let me repeat : FULL |
#34
latency is a much bigger problem for mixing
just my opinion when mixing i don't want to get hassled with delaying tracks etc... during recording i don't mind removing some temp plug ins to achieve no latency |
#35
So far what I hear that sounds reasonable (and some of which I have verified through testing) is that (we think) there is PDC in LE, but only up to 2000 samples. The delay shown is what goes over and above the possible compensation and is in fact a "net" delay. Low latency monitoring is possibly the result of disabling this PDC (thereby keeping us from running plugs). This all sounds possible to me, but REALLY where is Digi on this??? I really wish someone would clear this up once and for all, especially if Digi is trying so hard to get us all mixing in the box.
This is important stuff, especially between tracks with bleed from other tracks (drums etc) as phase is concerned. For now, I plan on doing the following: For any tracks which contain information common to other tracks (snare and overhead, or parallel compression auxes, for example) I will be aware of phase problems due to plugin delays and compensate by nudging, inserting and bypassing identical plugs, or printing the effect with the Audiosuite equivalent. For tracks without common information (guitar track and a vocal overdub track, for example) this delay is not such a big issue- no more than any other very slight delay would be. In fact, unless the delay is greater than 660 samples (which would equate to 15ms in a 44.1 session) it is likely that we wouldn't even percieve it (between two different sounds). It would follow that these delays (again between two different sources, ie. tracks with no sounds common to both) would not begin to cause percievable timing issues (like noticeable misalignment between kick and bass, for example) until the delay were over around 2000 samples ( approaching 50ms in a 44.1K session). Does all this stand to reason with you guys? Again...Digi...please chime in and shed a little light. Ted |
When do you NEED plugin delay compensation? | JonnyGinese | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 6 | 03-17-2006 09:28 PM |
Will PT7 LE have plugin delay compensation? | Matiz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-17-2005 01:27 PM |
plugin delay compensation? | vieris | Pro Tools M-Powered (Win) | 1 | 06-19-2005 03:25 AM |
PlugIn and MIDI Delay Compensation - When ? | Detlef Brockmann | Pro Tools TDM Systems (Mac) | 2 | 11-25-2001 04:33 PM |
plugin delay compensation | liquid | Digidesign Hardware & Software | 0 | 08-13-2001 06:11 AM |
