Old 11-01-2016, 05:03 AM
alex s alex s is offline
Default PT 12.6 + HUI midi problems
I'm running PTHD12.6 (software only) on OS X 10.10.3 with a Mackie Control Universal set as a HUI controller.
For some reason it works fine (if a bit laggy) apart from the second fader won't write data... it'll play back though.
I've installed a midi monitor app and the mac's receiving midi info ok from the second fader.
I've noticed that within the midi monitor app each fader has a different "data" name when the fader is moved.
For example:
Fader 1 is: bank select
Fader 3 is : breath control
Fader 4 is : controller
Fader 5 is: Foot control
Fader 6 is: Portamento time
Fader 7 is: Data Entry
Fader 8 is : data entry
and fader 2... the one I have problems with is:
Mod Wheel
Does anyone have any clue as to what might be the problem ?
It was working fine in PT12.5.
Thanks,
Alex
Old 11-01-2016, 10:32 AM
Shan's Avatar
Shan Shan is offline
Default Re: PT 12.6 + HUI midi problems
The actual list is fine. That's the MIDI CC list that the faders use to transmit the fader data.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-01-2016, 10:42 AM
Thanks Shane,
Hmmm... strange !
It's weird that the midi monitor app is receiving data, but pro tools isn't : (
Al.
Old 11-01-2016, 11:42 AM
Shan's Avatar
Do you have a co-install(PT 12 & 10)? If so, open up PT 10 and see if the same thing occurs. Hopefully others can chime in with some other trouble shooting steps.
Shane
Midi Studio Setup problems & Plugin problems J Nauti MIDI 0 03-02-2010 11:04 AM
Problems with Midi sound / Midi Controller joe_04_04 MIDI 2 07-16-2009 12:43 PM
MIDI Problems with Axiom 25 MIDI Controller jasonguitar Pro Tools M-Powered (Win) 12 04-03-2007 10:04 AM
MIDI- problems Elli 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-03-2003 05:50 PM
MIDI NOTES DISSAPEAR!!?? WIERD MIDI PROBLEMS ManhtnProjct Pro Tools TDM Systems (Mac) 2 10-29-2001 08:39 PM
