That old vocal sound.
Can anyone please tell me a technique I could use to achieve that old fashioned vocal sound. I don't really know how to explain what I mean but I have a sound in my head of what it is, I suppose 70's kind of analogue classic sound. Anyone have any ideas??? Sorry for the unclearness
Thanks L.Dudley |
Re: That old vocal sound.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Well the kinda style I Mean.
Johnny Ray - Cry, Somebody stole my gal, Just walking in the rain, Gla drag doll, Candy Lips Otis Redding - Sitting on the dock of the bay Jimi Hendrix - All along the watch tower, voodoo child, hey joe The Doors - Light my fire Some of the modern day acts I like for their vocal sound which is slightly different but in the same ballpark I'd say: The Strokes - Reptilia The Bravery - Honest Mistake Maybe the latter two are just using distortion or other FX. However the old ones I def would like to know. I hope this makes it clear. Thanks |
That is a well guarded secret..
cheers, Andrew W7 pro 64_i7 3930K_16GB_ Nuendo 6.5.4-7.1.3 / PT 12.4 ------Mac Mini OSX Lion_PT 10.xx Allen&Heath GS R-24M_ full rack of vintage analog boxes _UAD2_Nugen_iZotope_Melda_Waves_Plugin Alliance_DMG and more 2.0 and 5.1 monitoring |
the_dr38: for that sort of stuff, T-racks comes in handy with the filters and EQ to emulate the old style mics. Another deal would be to simply score an old style mic and run it through some form of tube based pre-amp which will give it that warmth/distorted texture a bit. Also, sometimes different effects might work for things of this sort, but that is where I would suggest starting for starters. goodluck |
in addition to a million other things, some of the tracks you mentioned use a short delay on the vox, maybe around 120-130ms.
U47-1073-1176 period. As stated above, a slight delay.
Cliff Stendel -iMac 5K 32g
-PT12. HDX -HD I/O 8x8x8. -HD Omni -Avid S3 -API 2500 -API 5500 -UA 2-1176 -UA 2-610 -Neve 1073, Chandler LTD-1 -Eventide H8000FW -Lexicon PCM96 -Bricasti M7. -Joe Meek channel. -Waves Mercury, Flux all, Softube All, Plugin Alliance all, McDSP all, Sonnox All, MH production, Wave Arts,a bunch more -Moog Voyager XL, Nord Piano, Hartmann Neuron, ARP Axxe, Gibson Les Paul, Mesa Boogie Roadster, Kemper, Taylor T5 and T5-12 |
McDSP Analog Channel AC2 (tape emulation) has filter options and tape saturation options. That and a little optical compression (like the Waves RenComp) and a vintage EQ (URS, Waves RenEQ) before it should do the trick. Overall, you'll hear the most desired "effect" from AC2. In fact, you may not need much more than that.
Oh, effects would also play a role. Slap delays and vintage reverbs would be a start. Try the "Slap Elvis" effect in Waves SuperTap 2 and some basic hall/room settings in Waves RenVerb. rockrev
End world poverty: ONE |
I agree with Rockrev. McDSP will get you close to the 'tape' sound. I would also start with a 'chamber' preset on your verb. 'Light my fire' sounds like a real chamber for the verb but it may be a spring reverb. A good IR style reverb should have some convincing 'chamber' sounds. You might also want to add a bit of vinyl sound for that extra touch.
Izotope Vinyl is cool and free. Tape delays also come to mind. You can imitate these buy using the stock Digi delay on an Aux channel and putting McDSP AC 2(Tape emulation) after it. I wouldnt use the feedback on the delay plugin though. I would create a send and bus this to the input of the aux channel itself. Then the number of 'repeats' would be controlled by the send fader. In this way, each delay repeat gets a little more degraded with each pass. The best approach would be to find out what was actually used and then imitate it with your plugins. And of course if you could find out the exact mic and pre combination etc and actually use them if possible, then you would even get closer to that sound. Shane
Vinyl is definitely cool, and I used it several times on my latest project. I've tried the tape loop trick too. The thing is, it always crashed my session for some strange reason. So instead I simply roll the highs off of my delays (aux of course) and in the mix it seems to be about the same (so long as the mix is busy). I'm guessing that the crash may be unique to my setup and/or simply more stable on a TDM system.
rockrev
Get That Tight Vocal Sound | RussUK | Virtual Instruments | 10 | 07-28-2009 09:41 AM |
Best Vocal Sound | woodzie12345 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 09-21-2005 02:29 PM |
vocal sound tips !!!! | jeam25 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 10 | 09-29-2004 11:39 AM |
Vocal Sound | ProTooler | Pro Tools TDM Systems (Mac) | 7 | 03-27-2003 09:14 AM |
BEST vocal sound? | Dennis | Tips & Tricks | 38 | 01-27-2001 11:17 AM |
