  #41
Old 09-10-2009, 01:18 AM
tj_davies tj_davies is offline
Default Re: Finally!! Tool section of the exact tool you want!
Originally Posted by Chompers View Post
Most people dont notice because they are very slow and deliberate.
And then there are smart people who use the tool. Ups, ahm, I mean: And then there are people who use the smart tool.
Tim
PS: I also vote for the option to lock any tool - and the pre- and post-roll setting - so everybody can customize Pro Tools the way they prefer to work.
Mac Studio Ventura 13.6
PT 2020.12.0
www.pearls-music.com
  #42
Old 09-10-2009, 01:36 PM
Chompers Chompers is offline
Ok, I think there is a confusion here.
I use the smart tool... plenty ...lots of smart tooling going on here.
That is not the issue.
This design flaw superceeds EVERYONES style of work.
IF you don't notice the flaw, then live with it alone and be happy.
Ive seen many a pro tooler, who doesn't consider it a flaw. fall victim to it.
IT really is a flow killa, and screws EVERYONE... even if they dont notice it.
There is no possible reason to consider the option to lock the tools a bad idea.
The only issue to is WHEN?!?!?!?!?!?!?!
  #43
Old 09-12-2009, 05:13 AM
Felix Rost Felix Rost is offline
Nope. Cant do it. QK WILL NOT see the pop up box that pro tools uses to select those options.
You could use the screen mapping. But then, every session would have to have the windows in the exact same spot on your screen for that to work...so....doesnt work.
Chompers, it DOES work here. I can drag around the edit window and it still works. This is for PT 7.4, maybe there's something different in 8?
http://felixrost.de
  #44
Old 09-12-2009, 06:41 AM
I have put up the QK shorty at macrosonline.net
http://felixrost.de
  #45
Old 09-19-2009, 08:19 PM
cool! Ill check it out.
  #46
Old 09-19-2009, 08:32 PM
I cant seem to log in to that forum.
Hmmm?
  #47
Old 09-20-2009, 01:46 AM
relaxo relaxo is offline
Originally Posted by DigiTechSupt
This is not a bug and the tools work as intended, however we do understand that this is a feature many people would like and we have this on our short list of features to be implemented.
Here is one from 2 years ago!!!
TWO YEARS Ha Ha Ha ha.
Chompers, you need to come up with a real good work-around, 'cause Digidesign will give you that feature in 2026, AT THE EARLIEST, but probably longer because they seem to be short staffed these days, totally unable to fix the most catastrophic of problems in under 2 years, much less ergonomic tool preferences.
It took PT composers ****17 years***** to get Digidesign to give us the VITAL ability to be able to just mute a damn midi note. Did you get that? 17 years!!! Digi is sloooooooooooooooooooo
Once more.... S E V E N T E E N YEARS
It just took Digidesign over two years to get MBox2's not to crash Intel Macs 10 times a day when using Core Audio. Two years...crashing all day... everyday. Don't believe me?
Chompers, get real...plan for 2026, if anyone in the music industry even has enough money to by ProTools by then.
  #48
Old 09-20-2009, 07:49 AM
Chompers, I could send you an email with the shortcut.
http://felixrost.de
  #49
Old 09-20-2009, 08:04 AM
Hmmm?
The signup process at bbs.macrosonline.net people say is tricky. Someone explains it in here somewhere. I'm not the guy running that site.
If you're running Quickeys, you REALLY want to run QuicKeys, not just with one shortcut, but with 20 or more, so therefore you'll want to sign up to bbs.macrosonline.net for sure. It will give you a steam-powered catapult start that the rest of us QK users wished we had.
  #50
Old 09-20-2009, 07:28 PM
Cool, I logged in.
Yeah, Ive been using quickeyes for many years. I have created a shortcut for this issue before. However, it wasnt fast enough not to screw things up.
Im about to try the one posted.
Thanks
Is is possible to change the shortcuts for the Pencil Tool, Grabber Tool, ETC? jgagne1 macOS 2 09-24-2013 07:46 AM
Weird Smart Tool/Selector Tool issue? Marsdy Pro Tools TDM Systems (Mac) 11 01-15-2012 07:22 AM
Get Grabber tool (Object) as part of smart tool? buckaroo Pro Tools TDM Systems (Mac) 8 07-13-2010 04:21 AM
Pencil tool turns into mouse pointer tool when drawing arvid.lind 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-11-2010 12:36 AM
Smart Tool / Pencil Tool in Midi Editor AndyJCP 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-26-2009 08:08 PM
