Real time streaming out of PT
Hi guys,
I need to do remote mix approvals on a project and instead of having the mix engineer burn mp3s and send them to me for tweaks I'd rather stream out of his Mac (out of PT outs) and listen to the tweaks real time.This will be a way faster way to go. I know you used to be able to do this with Nicecast, but not sure what software is up to the task in the modern era. I know this is probably part of the collaboration feature that is coming soon, but might anyone have any info that I can use on this? Thanks so much!
nz |
Re: Real time streaming out of PT
You can set something like this up with most Remote Desktop apps. There are also some good solutions from Source Elements.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Yep, source elements has a plugin that does this.
Steve Peach Stereo Missile Recordings Creative Director - Red Note Visionary Sounds: http://rednote.com.au Label: http://www.stereomissile.com/ Music Production / Mixing: http://www.stereomissile.com/musicproducer/ Mastering: http://www.stereomissile.com/mastering/ |
UPDATE TO THE OP... just noticed you were using NiceCast... read my post. IT WORKS!
Source Elements IF YOU WANT TO PAY THAT MUCH!!! I use an app called NiceCast, https://www.rogueamoeba.com/nicecast/ , which costs $60 and turns your ProTools edit station into a WebStreaming device. I do a yearly show for an NYC choreographer and we ALWAYS work on music edits this way. NiceCast produces a link for her to login from iTunes and she listens in realtime while I edit... there's a delay of about 2-seconds, depending on your upload speed. You can change ALL PARAMETERS of the webstream, and even add processing into the final output (i.e. peak limiting plugin) to keep it all together on their end. Works GREAT. You may need a little IT help to setup your router to pass the proper port, but it's usually a very simple process. Good luck... (I usually take an analog out of my interface and feed it into an analog input, having NiceCast look at that input for signal. That's the best way to do it since it won't see the out of your interface any other way)
Eric Seaberg • San Diego, CA A.E.S., I.E.E.E., S.M.P.T.E., S.P.A.R.S. |
Clip Gain won’t update in real time during playback on Elastic Time tracks | yanos | macOS | 0 | 06-03-2012 03:48 PM |
Real-Time Bounce to Disk...REAL PAIN | Brian in Charlotte | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 201 | 07-26-2010 08:12 AM |
Structure Real Time Time Stretch | FedericoF | Virtual Instruments | 3 | 02-18-2010 05:30 PM |
DIGI FEEDBACK: 'Real Time' Bounces-Time Effective? | csiking | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-20-2005 06:41 PM |
Time before real-time edits take place? | Captain_Pants | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-19-2002 05:23 PM |
