Pro Tools 10 doesn't see my Digi 002 Rack
Okay so I got a NFR full version of PT10 from my new job and installed it on my computer yesterday. I installed the new 002R drivers, did a clean uninstall from 8 and did a fresh install with 10. All plugs are compatible, system is optimized as usual. I have been running 8 flawlessly forever and have had minimal to none issues thus far.
Now there's PT10. Yesterday I opened up a previous session from 8 and everything loaded perfect. The 002R was "seen" by PT, I could hit playback and play around with Clip Gain, ADC, and have some fun. It was cool. Today I go to load up the same session and play around some more to get used to 10 and it no longer "sees" my 002R and throws up errors about my I/O. I have been doing the ritual of trashing prefs, yadda, yadda, yadda, re-installed the new 002R drivers, rebooted etc.... still nothing. It wants to start up with my Built-In Input as my playback, and also when I go into my Audio/MIDI Utilities in the Applications folder, my 002R is not even there. I'm calling Horse Pucky here Avid... You ALMOST had my money for PT10. I had it all saved up and ready to spend through my job, but they came through with a free copy.
Mac Pro Dual Quad 2.8Ghz 2008 MacBook Pro i7 2012 OSX 10.8.5 - OSX 10.7.5 Pro Tools 10.3.7 - 11.1.2 6GB RAM Universal Audio Apollo Quad!!! Eleven Rack Focusrite Octopre MKII Yamaha HS80s Rockit RP5 Monitors w/ RP10 sub |
Re: Pro Tools 10 doesn't see my Digi 002 Rack
I went through the ENTIRE troubleshooting stages.. I kinda know what I am doing. I have been using ProTools for 5-6 years now. I do indeed read ALL of the fine print. I have installed the latest PACE drivers, 002R drivers and.... As a matter of fact, I just ran Disk Warrior 4.2 to rebuild my directory. My Mac Pro can handle all of the ProTools 10 glory, it's been running versions 7 and 8 perfectly fine.
Still to no avail. I get the "ProTools could not initialize the current playback device. Please make sure the device has been configured correctly." So after all is said and done. ProTools 10 IS a waste of time and money. I'm going back to 8 until Avid get's their head out of their (_*_).
Well I haven't had a single problem on my Macbook, yet.
Have you tried reinstalling Pro Tools itself? Are you sure your plugins aren't to blame? Have you tried removing 3rd party plugs from the folder? Have you checked to see that the 002 isn't the problem? An 8 to 9 year old serviced interface, from what I can tell in your profile. Checked the FW cable? Tried just running off the onboard card? Plugged the 002 into a different computer with a different version of Pro Tools? I've been running PT10 since the day it was released with my LS56 on 10.6.8 and have never had an issue with playback devices.
D a n t h e I n c r e d i b l e S o u n d M a n "Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4 Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0 _C U R R E N T-D V E R B-S C O R E:515 |
It's not even seeing the 002R. weaksauce... I am at a loss here. Back to 8 I go.
Sounds like an 002 power harness issue
Rail
TH |
Does the Digi 002 show up in the Playback Engine dialog? If not (and it doesn't show up in Audio MIDI Setup) then it's more likely a Driver or Hardware issue... not Pro Tools 10 specific.
Guys,
Hi. Sorry to slightly hijack your thread, but I wanted to play the "squaeky wheel" because I see DTS has showed up here. DTS, any chance we could get some love over at this thread: http://duc.avid.com/showthread.php?t=311045 Cheers all. Steve Bush www.music180.com/pros/5887 |
This is looking like I might have to buy a new interface. Yeah that's not going to happen.
Do a CLEAN uninstall of PT8, reinstall PT10, restart, reinstall the latest 002 drivers, restart... the 002 should work (mine works fine on 10.7.2)
Rail
Avid Pro Tools 10 HD w/Digi 002 rack | westonbueller | Windows | 6 | 01-13-2012 04:39 PM |
will pro tools le 6.9 run digi 003 rack | cdrecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-30-2009 12:12 PM |
Pro Tools 7.3 can't find Digi 003 rack | Tony Kosinec | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 01-07-2009 10:41 AM |
Pro tools LE 7.1 with Digi 002 rack | dshipps | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-18-2007 03:25 PM |
PRO TOOLS 5.3 and Digi 002 Rack?! PLEASE HELP! | Dan M. | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-03-2003 10:10 PM |
