Old 11-03-2011, 02:27 PM
rtcstudio rtcstudio is offline
Default Audio tracks stop playing back/outputs disable
Sometimes, usually after I import some additional audio, some audio tracks just stop playing back.
The meter will move like there is audio, but you won't hear anything. Voice shows assigned. You can solo it...no sound.
Only two ways I've found to fix it. One is to save the session, close Pro Tools and reopen Pro Tools, then reopen the session.
The other way is to go to an offending track and just select the output it's assigned to and assign it again (to the same output works). This resets it and it plays again.
I searched but the only thing I found was a similar thread in Pro Tools 9 a couple years back.
Mac OS 10.7.2, Pro Tools HD 10 (using TDM Expansion chassis with OMNI HD I/O and one blue 192 interface)
Mac Pro dual quad 2.66 Ghz (8 core), 17 Gig RAM
HW buffer 512
Host Processors 8
CPU Usage 90%
192 voices (6 DSPs)
Delay Comp Long
Disk Cache 12 GIG (maybe I should lower this....)
DSP Cache is off
Old 11-03-2011, 03:51 PM
strawb strawb is offline
Default Re: Audio tracks stop playing back/outputs disable
same here. PT10 10.7.2 HD3.
you have to either restart PT or reassign to the same output again to get sound. and it's only after an audio import. hopefully this can be fixed ASAP.
Old 11-04-2011, 01:02 PM
Originally Posted by strawb View Post
same here.
It actually happens after importing session data as well, if any of the tracks include an audio file.
Pro Tools 10/11 HD, Mac OS 10.8.2, Mac Pro 2 x 2.4 GHz 6-Core Intel Xeon (June 2012) 64 Gig RAM, Avid HDX Card, OMNI HD I/O, 192 HD 16x16, Artist MC Control, Firewire audio drives, Sony Bravia 42" HDMI monitor, Acer 24" monitor
Old 11-04-2011, 01:06 PM
audiobob's Avatar
audiobob audiobob is offline
I just had this yesterday and today on 9.0.3. I'm working away and then no audio from a track. Levels are there but no sound.
Old 11-06-2011, 08:37 PM
SmokinBaldMonkey SmokinBaldMonkey is offline
YES, getting this like crazy. At least three times a day on multiple sessions for no particular reason I can discern.
Stopping, closing and reopening or relaunching the session seems to fix temporarily.
w.t.f.
I'm comping a vocal right now and after splicing in a phrase to my comp track, everything else in the session except the drums and box simply stopped making sound. All levels and meters functioning as if there is sound. Seriously.
mmmm....a thousand dollars....
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 11-07-2011, 01:04 AM
soundeq soundeq is offline
Yep, I'm having delay comp probs in 9.0.5 and really don't wanna fork out another $1k to "fix" something that may not be fixed.
I could be wrong...
Old 11-07-2011, 07:49 AM
still happening every day. a big inconvenience. i notice that some of these bugs/threads get an answer from avid support and some (like this one) do not. what does it take to get an acknowledgement/fix from avid?
Old 11-07-2011, 05:23 PM
Yeah, I would guess they are super busy, but would be cool to have a response.
Yes, I've tried to figure out most of the audio and session data that I want to import, and then do it all at once if possible so I can then resave as a new name and then restart Pro Tools so that all my outputs work again. It's just part of my working regimen right now.
Old 11-08-2011, 02:01 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default
Do you have Revibe in your plugins?
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 11-08-2011, 06:52 AM
chicken chicken is offline
Same here, happens regularly in pt 9.0.3.
I have no Revibe
New shoes always hurt.
some of my vocal audio tracks not playing back...help superdood Digidesign Hardware & Software 13 11-19-2021 08:31 AM
Audio tracks stop playing back/outputs disabled in PT 9.0.6 mingojr macOS 0 08-12-2013 05:25 PM
Recorded audio is not playing back in sync with other tracks ATLracing Getting Started 4 07-08-2013 05:52 PM
Those getting "audio tracks stop playback/outputs disable" Questions? crizdee macOS 15 09-25-2012 08:10 AM
Tracks Stop Playing Back 7.2.1cs1 tomhartman Pro Tools TDM Systems (Mac) 0 11-21-2006 01:36 PM
