Newbie question: How do I record from one track to another?
Let's say I have two audiotracks - one empty and one with audio and a bunch of plugins on it. Now I want to record the audio (with all the plugin effects) onto the empty audio track. How?
Re: Newbie question: How do I record from one track to another?
Change the I/O section to output to a buss - lets just say buss 1/2 (stereo track)
On your second track input buss 1/2 output your monitors Record enable your 2nd track and press record Should do it _ also you could search the PDF manual for bouncing tracks or something very similar - also they have nice pics in there with details of how to change the I/O section Cheers
Easiest would be just solo that track and bounce it out and import the bounced track back to the session. That is, the first time when you do the whole thing at once.
Later on, if you need to fix a ten second take (and have not touched your plugin settings and do not have anything random like reverbs going on), do what YYR123 just said.
Re the "New Track" trick, as cool and convenient as it is, if you do it a lot, your bus list will fill up fast
Hope that helps. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
So the reason I used this example was it sounded like Stefan needed a simple answer an easy trick
I don't doubt it can be done various ways - a wise man once said the cool thing about digital is that you can do things in many different ways....
I myself dedicate them to bus menu b for quicker access and better session management. For the track I want to quickly render with effects or VI's while creating a new track automatically, I'll select my render type from the audio output path selector of the individual track: Next I just hit Ctrl+Alt+B then select the Bounce Source and let it roll: Once you setup these initial dedicated render paths in your I/O setup, the whole process becomes very quick and easy. It will save you hours from doing real-time bounces or time consuming AudioSuite procedures. Hope that helps. Shane
Is there a trick to doing that? Thanks Rosco |
recording track question - newbie | cablet | macOS | 3 | 05-04-2013 10:26 AM |
Newbie question... setting the click track tempo | jdport2 | Pro Tools SE and Essential (Win) | 2 | 02-19-2010 06:32 PM |
Newbie Protools Question on track allocation | Johnrg | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 12-01-2009 09:09 PM |
Newbie Track count question. | abt | Tips & Tricks | 12 | 08-20-2009 07:23 AM |
Very Basic Newbie Question: Count Track.... | tenover | General Discussion | 2 | 07-27-2006 11:52 PM |
