plugin bypass in low latency mode
What's up guys,
Does anyone know why some plugs go into bypass mode when low latency is selected? And does anyone know how to keep this from happening? I'm using a plug called east west synphonic gold for strings and the samples are almost always late or behind the beat. This makes me have to place the midi notes at least one beat before the start of a measure because if I activate low latency the plug automatically goes into a bypass state. Please help!! Cheers!!! |
Re: plugin bypass in low latency mode
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
If this is the only solution there is nothing that can be done at present. This plug happens to require an active input to function. It's weird but necessary according to the info from the programers. I will just have to wait for a fix from them. Thanks for the speedy response.
Cheers |
The only other solution would be to unselect low latency mode, and then record at the lowest buffer setting. Also, print your midi tracks to audio, unfortunately, we have to do this in real time. Keep me posted. Shane
you are absolutely correct. however after my last post i started thinking that maybe the info I was referencing was dated. So I went looking for updates. Low abd behold I found one that I may have overlooked. Downloaded it, installed it and bingo!! Problem solved. Thanks man. You were a great help.
Killer!! Glad you got it working.
Shane
mono mode vs multi input mode in Audio Suite plugin? | thenewnoise | Pro Tools TDM Systems (Mac) | 4 | 09-30-2009 06:58 PM |
RTAS plugs lock to bypass mode | Atardecer | Pro Tools TDM Systems (Win) | 8 | 12-05-2007 10:16 PM |
AudioSuite bypass mode- micro loops | minister | Pro Tools TDM Systems (Mac) | 0 | 12-03-2006 07:37 PM |
TRACKING w/ REVERB PLUGIN in LOW LATENCY MODE? | minor2nd | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 8 | 07-10-2005 01:27 PM |
Waves L2 plugin wrong latency report in bypass | tapani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 10-22-2004 01:44 PM |
