Old 03-24-2017, 09:39 AM
Augusta Global Augusta Global is offline
Default Aphex Vintage Aural Exciter
Hello,
I have been using the Waves Aphex Vintage Aural Exciter plugin and this thing is just great!
A lot of people seem to run it: EQ -> Exciter -> Comp
Looking for feedback on different ways that people have used this plug.
I just used it on a hot guitar ( Joe Satriani style playing) and it added that something special to the sound. I don't think this is what it was intended for but damn what a great added touch to the sound.
Any stories about ways you have used this plug?
PT HD 10.3.10
ProControl
Magma PE6R4-I
1-Core/5-Accel
OS X 10.9
196 I/O
Old 03-24-2017, 11:06 AM
Default Re: Aphex Vintage Aural Exciter
Its best to simply try each order and see what happens. My personal preference is to run any "clarity" plugin last so the compressor doesn't undo the intended effect. when I say "clarity" plugin, I'm referring to anything that adds hi-end "air" which would include the aphex, as well as any Pultec model or the Maag EQ's AIR band But just because that's how I like to run, doesn't mean its the best method for you
Old 03-24-2017, 11:20 AM
Great point. I have it last in the guitar signal path most of the time. Yesterday it went:
Guitar DI into the board --> Waves GTR --> Eddie Kramer Guitar --> Aural Exciter.
I was just super impressed with the sound. I'm still on TDM so the delay was not an issue.
Tony
PT HD 10.3.10
ProControl
Magma PE6R4-I
1-Core/5-Accel
OS X 10.9
196 I/O
Old 03-25-2017, 12:20 AM
You should also try using the exciter FIRST plug in the chain, because as your guitar strings age they tend to lose high end crispness, so if dialled right you could bring them back to life with it -- then use normal processing with your "new strings sound"
Old 03-25-2017, 07:55 AM
I'll give it a try and see what I am able to come up with...
Thanks for the feedback.
Tony
PT HD 10.3.10
ProControl
Magma PE6R4-I
1-Core/5-Accel
OS X 10.9
196 I/O
Old 03-25-2017, 07:58 AM
Southsidemusic's Avatar
Thanks Augusta for this thread. Love the ideas and have to try this out this weekend The Aural Exciter is a very nice software and worth using much more than we have but as this thread says, the options are making the audio sound cool by using the plugin in various ways so this is a great thread. Keep it going and I will add after trying out some new thoughts tonight.
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 03-25-2017, 11:20 AM
Shan's Avatar
Shan Shan is offline
Originally Posted by albee1952 View Post
...My personal preference is to run any "clarity" plugin last so the compressor doesn't undo the intended effect. when I say "clarity" plugin, I'm referring to anything that adds hi-end "air" which would include the aphex, as well as any Pultec model or the Maag EQ's AIR band But just because that's how I like to run, doesn't mean its the best method for you
⇧⇧ Great tip Albee. My own "high end air" workflow is done via parallel processing in most cases. I also create my own "clarity/exciter" plug-in chain and channel for better control of the level and frequency range that I want to augment. I find that dynamic EQs, like TDR NOVA, do this quite well also. Trying the Aural Exciter in a parallel processing configuration on guitar can also elicit some great tones.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 03-26-2017, 09:23 AM
Shane
Interesting approach, and it reminds me of another(while we are on this subject). If you don't have the Aphex plugin, try this. Add an AUX send to an AUX track. On the AUX track, insert EQ III, enable the hi-pass filter and slide it up to around 3Khz. Follow that with a distortion plugin(AIR Distortion or Sansamp both work) and set for mild overdrive. Bring the AUX fader up slowly to taste. This is a great trick for making something(like a vocal) "pop" when volume doesn't do the trick
Old 03-26-2017, 12:25 PM
I like this!
PT HD 10.3.10
ProControl
Magma PE6R4-I
1-Core/5-Accel
OS X 10.9
196 I/O
Old 03-26-2017, 01:43 PM
amagras amagras is offline
Shane
I made the patch for the free version if someone wants it:
<TDRNova bandSelected_1="Off" bandActive_1="Off" bandGain_1="0.0" bandQ_1="0.71" bandFreq_1="50" bandType_1="Low S" bandDynActive_1="Off" bandDynThreshold_1="0.0" bandDynRatio_1="2.0" bandDynSplit_1="Off" bandDynAttack_1="0.18" bandDynRelease_1="23" bandSelected_2="Off" bandActive_2="Off" bandGain_2="0.0" bandQ_2="1.00" bandFreq_2="500" bandType_2="Bell" bandDynActive_2="Off" bandDynThreshold_2="0.0" bandDynRatio_2="2.0" bandDynSplit_2="Off" bandDynAttack_2="0.18" bandDynRelease_2="23" bandSelected_3="Off" bandActive_3="Off" bandGain_3="0.0" bandQ_3="1.00" bandFreq_3="1500" bandType_3="Bell" bandDynActive_3="Off" bandDynThreshold_3="0.0" bandDynRatio_3="2.0" bandDynSplit_3="Off" bandDynAttack_3="0.18" bandDynRelease_3="23" bandSelected_4="Off" bandActive_4="On" bandGain_4="12.0" bandQ_4="0.80" bandFreq_4="6000" bandType_4="High S" bandDynActive_4="Off" bandDynThreshold_4="0.0" bandDynRatio_4="2.0" bandDynSplit_4="Off" bandDynAttack_4="0.18" bandDynRelease_4="23" hpSelected_master="Off" hpActive_master="On" hpFreq_master="5300" hpType_master="24dB/oct" lpSelected_master="Off" lpActive_master="Off" lpFreq_master="40000" lpType_master="6dB/oct" bandGain_wide="0.0" bandDynActive_wide="On" bandDynThreshold_wide="-35.0" bandDynRatio_wide="10.0" bandDynAttack_wide="0.10" bandDynRelease_wide="10" bypass_master="Off" delta_master="Off" dryMix_master="94.5" gain_master="17.0" eqAutoGainParam="On" qualityParam="Precise" channelsParam="Stereo" analyzerModeParam="Analyzer: Out" sidechainModeParam="INT SC"/>
amagrasmusic.com
Aphex aphex big bottom pro/aural exciter bundle tdm rtas Tank Buy & Sell 0 06-10-2013 05:45 AM
Waves Aphex Vintage Aural Exciterฎ plugin bacchus40 Pro Tools 10 4 08-01-2012 07:02 PM
Q : Aphex Aural Exciter TDM Aquarius Pro Tools TDM Systems (Mac) 4 03-17-2008 10:12 AM
Aphex aural exciter Ricco Tips & Tricks 4 09-02-2000 12:02 AM
Aphex Aural Exciter AdamFrick Pro Tools TDM Systems (Mac) 1 11-12-1999 01:36 PM
