#51
Re: Waves Will NOT Be Supporting AAX-DSP!!!
#52
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#53
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
#54
These system are really for live sound but in general I would say it's AVID that wants to push a closed solution where they make the bucks on the high-end hardware and the main software and control the development approach. From the soundgrid white paper. Latency (roundtrip total)40* samples / 0.83 ms80* samples / 0.83ms"Audio Processing Taking advantage of today’s extraordinary CPU power and the memory capabilities of Native processing, SoundGrid runs on standard CPUs under custom optimized Linux OS, resulting in predictability, stability, and low latency that was previously exclusive to dedicated DSP-based systems. Consequently, SoundGrid can run large numbers of Waves plug-ins, as well as extremely CPU-intensive plug-ins that are beyond the capabilities of DSP-based systems. " |
#55
There's no reason not to think 64 bit Pro Tools won't have this kind of native capability when it no longer needs to be compatible with RTAS and TDM.
Bob's room 615 562-4346 Interview Artists are the gatekeepers of truth! - Paul Robeson |
#56
D
ProTools 9.02 2 x Intel Xeon x5675 3.07GHz Hex Core 48GB RAM Windows 7 (x64)Pro RME Multiface II Intensity ATI HD5400 series graphics card |
#57
Shane
#58
DSP: Native Start putting DSP plug-ins in series without being careful or even aware of this, and you'll definitely hear the latency. The latency of the plug-ins get added to the throughput latency of the hardware I/O. DSP cards alone do not guarantee a latency free recording environment, just by the fact that plug-ins themselves arent latency free. Insert Maxim and tell us your latency free. Sorry if you took offence to my post, but you need to back up what you're claiming as fact, which you have yet done. I've clearly demonstrated and shown my claims which anyone can go see and hear themselves. In regards to your HDN statements, since you've never even tried it and somehow believe it's the same as your past PT LE/G5 experiences, I wont waste time on such a debate. If it really did what your claiming it does, none of us would even own it. Shane
#59
"The table below indicates how much latency (in samples) is produced by each Waves plug-in." That's deceptive. They should point out that native plugins are dependent on an environment of host-induced latency from the start. You will never monitor through a native plugin with anything approaching 0 samples of latency, and in just about every situation the latency will be less through a DSP-hosted plugin vs a native plugin. Having spent years being forced to tweak my host buffer setting to successfully run native VI's I am painfully aware of this fact. You talk about 96kHz sample rates and a 32 sample buffer... how about all the music studios still working at 44.1, which is still by far the most common sample rate I come across... what's that latency native? And how about when you're at 60 or 80 or 100 tracks and still cutting vocals into the session? You still running at a 32 sample buffer on the native system, and if not, what's the buffer setting at now, and what's the total latency at now? On the TDM system it's exactly the same as when you recorded the first track in your session... with 100 tracks, still less latency through a TDM plugin than through the native plugin in a session with one track. |
#60
On a different note, adding native plug-ins to a DSP system is a whole other story. I avoid that at all costs. Shane
Playback engine not supporting 44.1 kHz | cgunn | Pro Tools M-Powered (Win) | 0 | 07-02-2007 03:52 PM |
Digidesign supporting XP all the way! | gabriel_p | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 26 | 09-21-2002 11:10 AM |
any words on supporting DUAL CPU?? | Thomas Chiu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 08-01-2001 04:07 PM |
Supporting 5.1surround | afj | Pro Tools TDM Systems (Win) | 0 | 01-14-2000 02:10 AM |
PT/NT 4.2.5 supporting PT/Mix hardware? | DNS Studios | Pro Tools TDM Systems (Win) | 2 | 02-10-1999 03:59 PM |
