Phase invert
Ok, this will sound dumb...
I'm just starting with Pro Tools so I wish to know if there's a way I can invert the phase of an already recorded track. Is there a way? Thanks. |
Re: Phase invert
you can either process the track by going to the audio suite menu selecting the Invert plugin highlighting the region/s that u want to invert the press process.
or.... you can put a RTAS plugin such as a Digi EQ or Compressor (some other plugins contain it also) on the track you want to invert the phase and push the Phase Invert button in the plugin.. if the only reason u have the plugin on the track is to invert the phase and are not using it for anything else, i would first put the plugin on the track and invert the phase to make sure thats what you want to do, then after that I would process the track.
www.klarityrecordingstudios.com |
Re: Phase invert
The 'Trim' plugin. Hit the 'phase' button. Thats what it's for.
Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Phase Invert on the 003 | thebreaksnyc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-26-2011 02:18 PM |
How do you invert phase in PT? | Gunnell | Pro Tools M-Powered (Win) | 1 | 11-14-2006 08:11 PM |
Phase Invert? | barish | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-24-2006 05:37 PM |
invert phase help | keithaska | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-07-2006 05:09 PM |
How do you phase invert?... | marcelloz | Tips & Tricks | 1 | 07-12-2001 07:13 PM |
