Autohotkey shortcus
Has anyone found a workaround for the lack of free key combinations and the fact that PT hijacks ALT and START keys ?
I've tried using Print Screen as an alternate modifier but it seems to only work randomly...
Win 10 pro, Asus Rog Maximus, i9 [email protected], 64GB PTHD native, 2x96IO, SSL Delta Link, S3 |
Re: Autohotkey shortcus
Workaround for what?
Sorry, my question wasn't very clear. I've got an external programmable keyboard and I'd like to be able to program shortcuts that aren't available in PT natively (edit window scrolling modes, coalesce volume automation to clip gain, coalesce trim automation and so on). There are plenty of these that I want to program through Autohotkey but there are only a few CTRL and SHIFT combinations that are unused (ALT and START being unusable). So basically, my question is: how do I get 100 programmable keys to trigger AHK scripts ?
I'm afraid my poor english writing doesn't make it much clearer this time :-(
Unfortunately, this has been a known issue for years and was never a problem in older versions of PT. That said, any key can be used as a modifier using AHK. An ampersand may be used between any two keys or mouse buttons to combine them into a custom hotkey. You can define a custom combination of two keys (except joystick buttons) by using " & " between them. In the below example, you would hold down Numpad0 then press the second key to trigger the hotkey:
Code:
Numpad0 & Numpad1::MsgBox You pressed Numpad1 while holding down Numpad0. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Can you use it together with another keyboard (one standard, one just to trigger macros) ? "German" keyboard layout ? Mine is and I use : Edit , Automation , Thin all = Ctrl Shift T Edit , Automation , Coalesce Volume Automation to Clip Gain = Ctrl Shift Q Edit , Automation , Coalesce Clip Gain to Volume Automation = Ctrl Shift X Edit , Automation , Fades, Delete = Shift Delete Edit , Snap to , Previous = Ctrl Shift Ö Edit , Snap to , Next = Ctrl Shift Ä Edit , Trim Clip, To Fill Selection = Shift 1 Edit , Cut Special, All Automation = Shift F1 Edit , Cut Special, Pan Automation = Shift F2 Edit , Cut Special, Plug-In Automation = Shift F3 Edit , Copy Special, All Automation = Shift F5 Edit , Copy Special, Pan Automation = Shift F6 Edit , Copy Special, Plug-In Automation = Shift F7 Edit , Clear Special, All Automation = Shift F9 Edit , Clear Special, Pan Automation = Shift F10 Edit , Clear Special, Plug-In Automation = Shift F11 Clip List = Ctrl Shift < Options, Edit Window Scrolling, No Scrolling = Shift Arrow Left Options, Edit Window Scrolling, Continuous = Shift Arrow Right Options, Edit Window Scrolling, After Playback = Shift Arrow Up Options, Edit Window Scrolling, Page = Shift Arrow Down Options, Solo Mode, Latch = Ctrl Shift Arrow Left Options, Solo Mode, X-OR (Cancels Previous Solo) = Ctrl Shift Arrow Right
PT 11.3.2 HD , RME Fireface 800 , Genelec 5.1 , Win7 64bit Professional , i7 3930 Hexcore , 48GB Ram , SSD System + SSD PT Session/Audio + SSD Video (all Samsung 840 Evo) + Spinner 1TB Data , 2x Radeon HD 5450 \\ SD 633 Femto MKH8060 MKH8070 MKH30/MKH40 DPA4060 |
I use and Expertkeys EK-128 that I bought on eBay. Yes I use it along my normal Swiss french keyboard and it has 128 programmable keys. Thanks for your list, I didn't think there were so many key combination left...
So with that 2nd keyboard, you do not need actually shortcut combinations, as you can assign, maybe , Key 001 on the EK-128 is " Scrolling - No Scrolling" ?
That would be great. In case you need some "free" shortcuts (not used by PT), I made a list, to my best knowledge, scanning the Ref Guide and the Shortcuts Guide, but for a German keyboard. It is a PDF derived from an Excel Sheet. If the PDF is of any use, I could email you the Excel Sheet, to "translate" it to Swiss/French.
X-Keys devices work well with AHK if you want to extend your current keyboard. I set one up for a local user a few years back.
Shane
Thanks for the list Jerome
Thank you for this confirmation (parallel keyboards). I hesitated to spent the money to check out the EK-128, but your thread "pushed" me to do it. Just bought it.
Anyone using Autohotkey? Is ther a way to send the Windows key? | abt | Windows | 15 | 11-07-2014 06:25 PM |
