Re: Native system over TDM WOW!
A couple of things: The converters in the HD system
are better. A studio that's made the investment to purchase HD is going to have a well thought out space, good mics, good pres, so it'll be easy to get a good sound on the way in. Digi002R has good, quiet converters in my experience. I'm not going to go into the minute "colors" that different converters and clocks impart on the sound, but you can definitely do great work on any product in Digi's range. To do the test that was mentioned between a 002R system and an HD1, you're not going to need stuff like a MIDI, because the 002R has Midi I/O built in. Having run a TDM system for a few years and now having my own room with a 002R, I can say taht the TDM system was more stable. That's probably unique to my experience though and nothing universal. I love my 002R, I love the TDM systems. The TDM systems have repeatable results, you know exactly how much power you're using at all times. The native systems have come a long way since they launched the 001. Think of it this way: TDM is like a Studer while the natives are like Otaris. Dan Roth Otitis Media otitis-media.net
Dan Roth Otitis Media otitis-media.net |
Well, I don't know if it's that cut and dry. After all, you can still use whatever converters and clock as your front end of a 001 or 002. I myself am getting a Rosetta 800 and Big Ben to front my 001 (possibly soon to be 002), which will give me the same converter and clock quality as any TDM/HD system.
Shan (or anyone else)
I've heard about the VST wrapper-but are you sure this will enable us to use UAD1/Powercore with a PTLE rig? This would be very good news!
Matthew 11:15 |
Yes, it has been confirmed by Angus himself from FXpansion Audio, the Powercore/UAD cards will work in PT with the VST/RTAS wrapper.
I went this route a couple years ago and asked these same questions. After working with guys with TDM systems, they still can't believe I'm getting these great sounds out of a 001. I say invest in better converters and pres myself.
digi 001 650.00 Cranesong HEDD192 A/D D/A 2800.00 Great River MP2NV Preamp 2150.00 A7M266 with XP2100+ 600.00 Total: 6200.00 I'm very happy! Allen |
#16
We will not be supporting PDC out of the gate, nor are there any immediate plans to do so - the Digi Audio Engine doesn't support it, RTAS doesn't support it, so there is no way to do it. However, the latency running the PowerCore and UAD-1 as RTAS plugins is only 32 or 64 samples, and is reported in such a way that you can slide your tracks over to compensate. So, yes UAD-1 and Powercore will work as far as processing audio goes, but you will have to deal with any latency/PDC issues arising from their use manually. -------------------- =============================== Technical Director (CTO) FXpansion Audio UK Ltd www.fxpansion.com Shan (We have to deal with latency in HD also. Thats why we have the 'Time adjuster' plug-in in HD. With 32 samples I wouldnt bother but nudging tracks isnt hard to do quickly if needed.)
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
#17
Just a comment to Rail Jon ..
If you've bought your HD rig just to use a Sony EQ, then you should have waited for the Powercore support for Pro Tools LE (with the FXpansion RTAS adapter) you can get the Sony Oxford EQ for it. You mentioned the Sony EQ as a reason to go for HD .. I DON'T agree! Someone talked about the converters being a reason for stepping up to HD .. well that's not worth it either. Buy a good mic pre with a digital option and great converter/s (like the Mindprint DTC) and connect it to Digi001 via SP/dif (voila!) We're talking thousands of dollars here .. the HD should be many, many, many lengths ahead of a Digi001/002 system in EVERY way for that price !! (and it's not..but it has some options that Digi001/2 don't have) |
#18
I didn't say it was the only reason.. I said it was a good reason.
I've owned a TDM rig since the early 90's -- my LE systems are used for mobility or if I require a second system for editing or doing minor overdubs -- and yes, I usually use external converters when recording with it. I only use the mic pre for talkback. Not because of any reason other than I like using my Neve and API preamps for tracking, and more than likely use a compressor before I hit the A to D. I regularly require more than 32 tracks, and mix using Neve consoles.. so I definately require a TDM system... I love the fact that I can take my FireWire drives home and do most of my edits on my 002 tho'. I'm also eager to try out the FxPansion RTAS adapters. Considering the fact that soon there'll be input switching and PEC style recording available with HD, the extra DSP for new plug-ins on Accell, Beat Detective, integrated synch support, good sounding converters.. all make the HD price worth it IMO. If you're using the gear professionally, and billing a reasonable rate -- you should be able to pay off an HD rig in a month or two. Rail
#19
beat detective...BEAT DETECTIVE. mmmmmmmm.
64 busses make difference for me too, as well as preferring to mix through our analog console, and hence being able to do greater than 16 o's. 192 don't hurt either, though not an option for mix. Timecode (!) but now dv toolkit for LE. nice to have the a...z quicks now. score another one for LE. Just finished a session in a studio where the owner lamented his payout for 2 processes cards, purchased one month before the ACCEL cutoff. ouch. that do hurt. 31hz |
#20
follow this link for some cogent thoughts on native processing http://ardour.sourceforge.net/native-processing.html
www.redcottageproductions.com |
Pro Tools 10 native on HD2 system | rb99 | Pro Tools HDX & HD Native Systems (Mac) | 4 | 10-19-2013 09:45 AM |
aax vs. dpm (Native system) | colinmansfield | macOS | 2 | 04-12-2012 12:56 PM |
Old Mix System to HD Native Upgrade | Stillmorningrise | macOS | 10 | 03-02-2012 08:56 PM |
HD Native on an XP system | dccarson | Pro Tools HDX & HD Native Systems (Win) | 7 | 01-11-2012 01:23 PM |
native system? | thenassaproject | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-26-2010 06:40 PM |
