#41
Re: It's that time again, PT 9 Suggestions!
Assuming Digi is working on Pro Tools 9, then they have already decided what to work on and this is all a waste...
IMO they need to fix PT 8.x And they need to give us PPC users the updates and fixes of 8.0.3 FIRST. Taking care of the installed base should have the highest priority. Fixing bugs should have the second highest priority. New software with NEW bugs should have the lowest priorty. But hey, it's all about the money... kopper |
#42
How about on importing settings from another session to the current mix they separate out automation controls. So you can choose to bring in the automation or not.
#43
In response to Oliver M They could also do an Adobe CS workspaces type of thing with a set up of your favorite windows. Resized etc. to how you like them. For midi you could open up a workspace that has all your favorite settings. When doing audio you could do the same. Just switch the workspace to your preference depending on what you are working on. |
#44
I mean seriously guys, PT 8 is barely stable and you can't even run video with it now. Why are we even talking about PT9? Do we just give up on anything working well anymore? Does anyone remember PT5.1?
#45
I remember 5.1 - there are but two of those rigs still running here. I think this type of thread is a good litmus test for Digi to know what we're most concerned about. The video aspect is important - I've been resetting a Canopus three days a week between sessions on eggshells hoping it won't crash PT. I'm with you. But we need to have the gaps filled in as Digi/AVID keeps moving forward. - I/O / System settings lock would be huge. - DSP Cache sorted out would be great (so I don't have to keep turning it off). - Fade Files being re-tooled would also be great - but I've found that if there IS a problem with Fades (and sometimes I have about 10,000 in the folder), I can delete the Fade Files folder and let PT 'rebuild' the folder, which can be faster than letting PT search for Fades wherever they may be.
... but does it help the chorus? |
#46
I do! I do! I did Pro Tools tech support back then at NYC studios I remember: - the endless streams of system killing b-tree errors happening non stop on PIECE OF **** scsi drives, running norton utilities every day, every few hours sometimes to keep apps from crashing -restarting 30 times, trying every possible permutation to single out that pesky conflicting extension. -A flimsy OS9. Unix OSX 10.6 is building a DAW on bedrock. OS9 was building your DAW on balsa wood. Just that difference alone negates anyones statement who say the day of 5.1 was better. -I remember pathetic junk monsters like Quadras, Performas and Centras...compared to our 8 Core Mac Pros?!? Our machines have enough muscle to tear through any bottlenecks or problems. - remember being able to run maybe 1 or 2 rtas VIs. "You want VI synths that you can run more than two of? Sorry, you have one choice...Virus TDM." (Luckily...soooo luckily that is arguably the best synth ever made.) - a laggard PT software development team. A bit earlier, it was a well known fact that Logic 4 could do way more in editing or mixing on PT III hardware than Pro Tools software could do on PT III hardware!!! - A PT 5.1 software that you couldn't do jack **** on unless you wanted to record, edit or mix audio in. -OMS..."give demerit where demerit is due." -And most of all, I remember the crap digital 888 conversions and painful digital summing. To sum it up, I remember very clearly, it sucked.... terrible sound quality on totally crap flimsy systems on crap computers and multitudes more help calls from studio managers. Yeah PT8 is far from bug free, but pleeeeeease!
Mercy Sound Recording Studios NYC http://www.mercysound.com/ facebook.com/mercysound/ instagram.com/mercysoundstudios/ Next Generation Pro Tools-Realize the only plugins needing to be active are on the track you're currently editing & those affected by it...all others should be quickly, seamlessly and auto background rendered into audio. Now dust off your G5s. |
#47
A few more features
• Being able to see 2 Quicktime pictures in any session. For those in films and tv, this would be a tremedous help for making recuts • Being able to have 2 sessions opened at the same time. Rather than take the long PT convoluted way of importing sounds into another session, simply drag and drop between sessions is what we need • Settings Lock • When you export a region group....it would kind of be handy if it kept all the automation and levels etc in the region group. There is little point exporting them if on import into another session it resets everything to zero within the region group • When recutting tracks, that the comping tracks are recut also. Whats the point using comping tracks in Post if we can't reconform them I do wonder if any of the features are thought through properly...they certainly aren't with Post in mind thats for sure |
#48
I'll stick to the bare essentials, upon which many features requested here are based anyways:
-Offline bouncing -True unlimited automatic delay compensation You'll never go anywhere forward with a modern DAW without that foundation. Aside from that, PT does pretty much everything I want it to for now. |
#49
the ability to delete multiple non contiguous playlists without having to constantly re-open the "delete playlists" window
Being able to choose if you want TDM to reshuffle all your DSP when you add a plug-in? Or just be able to simply the DSP reshuffle process on TDM if you don't feel like waiting half an hour for it to recalculate DSP? How about "Show only active tracks" as an option in the show hide window? And then ridiculous requests like, Could I have more than one session open at a time? Stop charging for a feature as basic as MP3 export? How about a non-real time bounce? How about automatically switching some plug-ins to RTAS plug-ins when there aren't enough resources in TDM? Plug in Chains please? And perhaps a browser for plug in chains. A good browser. |
#50
1- Delay compensation in LE for compatibility with HD.
2- add Pref to "lock out" time stretching tool from the trim tool. 3- fix the multi-mono signal generator. its out of phase. 4- add a phase flip and trim knob to every track. No need to use up a insert slot for such a basic function at this point. 5- add a "lift from output assignment" button. say a track is assigned to output 3-4 and has a bus send set to bus 1. I want a button that can stop the post fader signal going to output 3-4, but still want the signal to go to bus 1-2 without resorting to track duplicating cumbersomeness. 6- Less doodads ahead of track names in Show/Hide window. There are like a zillion different graphical characters ahead of the actual track names and all I need the window for is hiding or showing tracks. I hate having to make it half the size of my screen for me to read the track name. 7- ability to use stereo tracks without having to convert to split stereo. 8- a truly functional "optimize for system" button in the "playback engine" dialog. I just want the thing to figure out what the maximum performance my system is capable of and just set it and forget it. 9- General improvement in sound quality from stock hardware. Last edited by ajv205; 02-03-2010 at 04:28 PM. Reason: typo |
Drum Loop Suggestions for Odd Time??? | RokVox | Virtual Instruments | 3 | 05-02-2007 10:34 AM |
Drum Loop Suggestions for Odd Time??? | RokVox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-01-2007 03:46 PM |
its time for something new. (suggestions) | mimon | Storage Subsystems | 1 | 07-04-2005 03:02 PM |
decision making time has come - any suggestions? | stephen duffy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 09-30-2003 10:11 PM |
time compression bugs/suggestions | mike connelly | Pro Tools TDM Systems (Mac) | 6 | 04-10-2000 02:03 PM |
