Old 11-13-2013, 05:28 AM
Blues Bird Blues Bird is offline
Default New metering - what is useful for gain staging?
How do you guys use the new metering options in PT 11HD for proper gain staging? I wonder if its useful to switch the track metering to VU to get a more analog like metering experience. Or would be meter like Venue the better choice, because it shows the peaks better ?
Old 11-13-2013, 07:21 AM
Drew Mazurek's Avatar
Default Re: New metering - what is useful for gain staging?
I believe the default is Digital VU for channels right?
That's what I use. It forces you visually to resist the urge to drive levels up like you did with those nasty, super fast peak meters PT used to have.
You set the levels just like you always did (make it "look" good on the meter) and provided that you don't mind your waveforms being a little smaller, all is well in digital land!!
www.drewmazurek.com
Old 11-13-2013, 09:25 AM
DetroitT's Avatar
DetroitT DetroitT is offline
I go between the legacy Pro Tools and K-20 mostly.
I do use analog VU's on my final mix out (Not Monitors) Which keeps me pretty tamed and are pretty much in line with what the PT's VU variation is.
Old 11-13-2013, 09:40 AM
I use Venue metering for tracks and K20 for master
Old 11-13-2013, 10:21 AM
Venue Peak or RMS? And do you know what "venue" stands for?
Old 11-13-2013, 10:27 AM
Venue is an Avid product.
http://www.avid.com/US/products/fami...-sound-systems
www.drewmazurek.com
Old 11-13-2013, 12:49 PM
Shan's Avatar
Shan Shan is offline
I use the Pro Tools Classic metering option. My main use of meters is to quickly see what track has signal or not and that's about it. It's the ears from that point on.
Shane
Pro Tools Power User Editing
Give your plug-ins a facelift...and skin 'em!
"Music should be performed by the musician, not by the engineer."
Michael Wagener 25th July 2005, 02:59 PM
Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit
Old 11-13-2013, 01:10 PM
Emcha_audio's Avatar
Emcha_audio Emcha_audio is offline
VU all the way, and only to glance at the global balance, ears (as shane stated) does the 95% of the work.
Manny.
Wave-T.com
Old 11-13-2013, 01:17 PM
Can someone explain to me how your ear tells the difference between -20dBFS and -6dBFS unless your control room volume is calibrated?
The OP asked about individual tracks which to me points to basic setting of levels. How do your ears do that?
www.drewmazurek.com
Old 11-13-2013, 01:47 PM
SpinningDisk's Avatar
SpinningDisk SpinningDisk is offline
Now now....
Sent from my iPhone using Tapatalk.
PT 11, PT LE 6.0, DIGI 001, DIGI 003, 27" Late 2012 Intel iMac, Blue and White G3, Reason 7, Celemony, Waves, A.I.R., Softube, XLN Audio, IKmultimedia, Massey
Alesis Masterlink, Alesis Adat LX20,
, Yamaha Motif ES8, Sure SM58, Sure KSM27, Byerdynamic MC 834 N, Event Project Studio 6, Pod Line 6, Focusrite Trakmaster Pro DI, Glyph Drives, Lexicon,
Fender Strats, Ibanez Acoustic, Ibanez Bass, Ibanez Electric.
http://www.johnackermusic.com/
[email protected]
Live and Let Live
Gain Staging?? Raoul23 Getting Started 20 07-05-2016 10:00 AM
Gain Staging username_1 General Discussion 2 11-12-2010 12:41 PM
Gain Staging (i.e. +6 db = 0?) carmichael Pro Tools TDM Systems (Win) 2 03-14-2008 11:02 PM
Gain Staging RNP into mbox bilco 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-26-2007 10:10 PM
Gain Staging wolfskin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 12-31-2005 11:02 AM
