MIDI notes continue sounding even after stop the record
Hi friends, I need your help, I have a Co-Install Pro Tools 10.3.9 and 12.3 protools
In the protools 10.3.9 when playing a midi, assigning the midi out to Roland Fantom x6 as midi controller, protools crashes, and crashes pc In protools 12.3 when playing a midi, assigning the midi out to Roland Fantom x6 as a MIDI controller, the pasted notes remain . Some MIDI notes continue sounding even after stop the record I've tried changing the USB cable, I used another controller midi yahama, and still the same problem |
Re: MIDI notes continue sounding even after stop the record
"Common" issue with Midi devices, hit-panic button, or program one to your midi controller.
All notes off. Cc123 value 0. All sound off Cc120 value 0. https://www.midi.org/specifications/...midi-message#3 Usually caused by too much Midi information, active sensing, MTC, MMC, etc... Or a bad timing clock. Or radio/electric noise in the signal. Or a dirty power supply, Or a midi feedback/Loop. Or a bad ground "in the cable." Or the synth, etc... https://en.wikipedia.org/wiki/Panic_button#MIDI Midi USB is not the best, specially in W7. But there are plenty other options. Available. |
What audio interface are you using ? Do you have the lastest driver installed ?
Mac M1 Studio Ultra - Sonoma Beta OS Avid Carbon Interface Protools Ultimate |
Hope that helps. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Hello friends, thank you very much for your answers, I tried protools, the key command Control + Shift + Period (.), My driver fantomx6 silence stuck MIDI notes, however when I return midi recording and playback, the problem returns = / I clean my pc power supply, I checked all my wiring interface, I change the MIDI cable and wires auido, but the problem persists, I tried my midi controller in the reaper version 5.15, and I have no problem midi in that program, the problem is only in version 12.3 of protools ..
Hello friends, thank you very much for your answers, I tried protools, the key command Control + Shift + Period (.), My driver fantomx6 silence stuck MIDI notes, however when I return midi recording and playback, the problem returns = / I clean my pc power supply, I checked all my wiring interface, I change the MIDI cable and wires auido, but the problem persists, I tried my midi controller in the reaper version 5.15, and I have no problem midi in that program, the problem is only in version 12.3 of protools .. |
Can you unistall your current driver and install this one please :
http://secure.digidesign.com/service...&localeCode=en There is a know bugs with the 003 drivers and this driver fix them all. Remember to trash prefences after the new driver installation . It doesnt hurt to try !
Have you got Local Off turned on on your keyboard?
Dave Marsden UK |
MIDI Start/Stop/Continue Help Roland MC505 | megabraun | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-22-2015 10:05 AM |
midi notes sounding when editing | songman | Pro Tools TDM Systems (Mac) | 4 | 02-23-2010 10:42 AM |
Structure midi notes not sounding | harryk | Virtual Instruments | 9 | 01-23-2009 05:58 PM |
Recording Midi notes and keeping existing notes during record | Sherbert99 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-15-2008 09:40 AM |
MIdi - All Notes Off at stop | The Drummer | Pro Tools TDM Systems (Mac) | 5 | 08-02-2005 01:44 PM |
